[WTS] GAB Suspension Products
Kent_Goh
GAB SP Series (Cool Sport Lowered Spring) Lowered & better handling.
Features & Benefits
- Made of SAE 9254 Steel
- Lowered 25-35mm
- Reduces body roll & increase handling respond
- Improve handling and stability on highways & cornering
Advance Technology Cold Forming
In contrast to hot forming where the spring is coiled at an elevated temperature, springs of our series are made through the technique of cold forming (normal temperature forming at a non elevated temperature). By using a dedicated new-type coiling machine, deterioration of the material is prevented and advance performance is retained.
*|G|A|B| SP Series come with 1 year warranty.
GAB SP Series (Sport Lowered Spring)
Rm250.00-600.00/set
GAB SA Series (Heavy Duty Sport Absorber) Extra long life span, Better handling, Comfort, Reliable, AVCS.
Guaranteed improvement of handling & comfortability
SA series are well balance heavy-duty sport absorber with Auto Valve Control Stability (AVCS) has the ability to be more effectively absorb the impact and vibration from uneven road condition, and provide maximum grip and traction. Superb handling, high stability and comfortable is SA series successful point.
Compatible with all type spring
Unlike standard shock absorber, SA series sport absorber compatible with standard spring or sport-lowered spring without sacrificing ride comfort and absorber’s life span.
Lower price & affordable
Auto Valve Control Stability (AVCS), high-pressure nitrogen gas fill in, strengthen absorber structure, double up life span, all this great feature came with reasonable price
*|G|A|B| SA Series come with 1 year warranty.
Rm600.00-1000.00/set
GAB HA Series (Winding Road Height Adjustable Coilovers) Front & rear height adjustable, Maximum grip and traction, Superb handling, High quality & performance, AVCS.
The BEST height adjustable shock absorber for the Beginner
Bumpiness and roughness are eliminated as much as possible and persistent setting that gives moderate rolling speed at cornering is achieved, to fit any winding road or any streets in the whole wide world.
Full height adjustable with Auto Valve Control Stability (AVCS)
The spring rate and damping force are set to minimize the sense of incongruity when changed from OEM components, so that everyone, including all the passengers, can enjoy sporty driving with NO discomfort. Also, simple adjustment systems, which are ride height adjustment function by seat positioning, make it very easy for anyone to handle.
Thread type height adjustment system
We have adopted thread type ride height adjustment system, with proper case length. Also, threads are coated with chrome plating, which has superior rustproof performance.
Auto Valve Control System
AVCS is an internal system that adjusts the stiffness of the suspension. It uses multiple layer valve spring to sense the road condition and automatically reduces or increase damping force according to the road condition and your driving style. The result is superior handling and maximum comfort on all road condition without having to manually tune or adjust the absorber.
*All products series of |G|A|B| come with 1 year warranty.
Rm1300.00-1900.00/set
GAB SE Series (Street Enchane Full Adjustable Coilovers) 2-way independent height adjustable, 15 Level damper rate adjustable. With latest AVCS2 & ESV technology.
Mono-tube structure
Mono-tube shell case is adopted to enable very fine control of the machine and aggressive yet detailed communication with the road surface. It generates and maintains very stable damping force, which even stands the intensive and repeated runs on the circuit, reacting to the tiniest data from the road surface.
Extreme accuracy damping adjustment
For finer settings, total of 15 different kinds of damping force are available, by adding the systems at piston rod. Use of specially shaped needle valve enables linear damping force adjustment at every 15 levels.
2-way independent height adjustment
2-way independent height adjustment system with movable lower bracket has been adopted, which enables the separate adjustment of the ride-height and pre-load.
Auto Valve Control System Version 2
AVCS-2 is an internal system that adjusts the stiffness of the suspension. It uses multiple layer valve spring to sense the road condition and automatically reduces or increase damping force according to the road condition and your driving style. The result is superior handling and maximum comfort on all road condition without having to manually tune or adjust the absorber.
Application List:
Honda Jazz GD
Honda Jazz GE
Honda City GD
Honda City GM
Honda Insight
Honda CRZ
Honda Freed
Honda Integra DC2 (Rear Eye)
Honda Civic FD
Toyota Vios NCP42
Toyota Vios NCP93
Toyota Yaris NCP91
Toyota Starlet EP82/91
Toyota Corolla AE90/92/100/EE90
Toyota Corolla AE101/EE100
Toyota Corolla AE111/EE110
Toyota Altis 01'-07'
Toyota Wish 1.8 2WD ZNE10G
Toyota Camry ACV30
Toyota Camry ACV40
Nissan Sentra B14
Nissan Sentra N16
Nissan Cefiro A32
Nissan Cefiro A33
Nissan Latio
Nissan Grand Livina
Nissan Slyphy
Mitsubishi Lancer 01'-06'
Mitsubishi Lancer GT 06'+
Mitsubishi Airtrek 01'-08'
Mazda 323 / Lantis
Mazda 323 GTX / BG/TX3/Astina
Suzuki Swift ZC31S
BMW E36
BMW E46
GAB SE Series (Street Enhance 15 Level Full Adjustable Coilovers)
Rm2000.00-2500.00/set
GAB SS Series (Super Sport 32 Level Full Adjustable Coilovers) 2-way independent height adjustable, 32 Level damper rate adjustable, Superb handling, Maximum grip and traction, High quality & performance, AVCS.
2nd from top ready for auto cross, gymkhana competition sports shock absorber
SS series is the 2nd from top among all series, combine up to date advance technology with the past many years of experience on auto cross & gymkhana race.
Mono-tube structure
For finer settings, total of 32 damping force are available, by adding the systems at piston rod. Use of specially shaped needle valve enables linear damping force adjustment at every levels.
Rm2000.00-3000.00/set
GAB SS-R Series (Super Sport Racing Full Adjustable Coilovers) 2-way independent height adjustable, 32 level damper rate adjustable, Enlarge monotube. Latest AVCS2 & ESV technology. Come with external canister.
Enlarge Mono-tube structure
External Canister
Allows for increased oil capacity and increased heat dissipation, which allows the damping force to remain more consistent during long term use. Most effective in racing applications where the vehicle is run for extended time periods.
Application List:
Honda Civic EG (Rear Eye)
Honda Civic EK (Rear Fork)
Honda Civic ES 1.7/RS
Honda Civic ES 2.0
Honda Civic EP
Honda Civic FD
Honda Civic Type-R FD2R
Honda Integra DC5
Mitsubishi Evo 7/8/9 CT9A
Mitsubishi Evo 10 CZ4A
Nissan Silvia S13
Nissan Silvia S15
Nissan 180sx / 200sx / 240sx
Nissan Fairlady 350Z Z33
Subaru Imprezza GDB (PCD 5 x 100)
Subaru Imprezza GDF (PCD 5 x 114)
GAB SS-R Series (Super Sport Racing 32 Level Full Adjustable Coilovers with External Canister)
Rm4900.00+/set
*Price might change without notification, kindly contact us thru SMS/Whatsapp 019 - 266 8138 or E-Mail [email protected] to check price, dealing method, product inquiries & technical issue. This is to ensure better tracking and a more efficient follow up. Thanks for your cooperation & understanding. Also, shipping & installation service provided with extra charges, please provide us your mailing address for shipping charge. TQ
*****Kindly leave me an message if i didn't pick up your call so that i can get back to you.*****
Regards,
XD-Autoparts - KentGoh
Website: www.xd-auto.com
Contact Person: KentGoh
Contact Number: 019 - 266 8138 (Prefer SMS)
E-Mail: [email protected]
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Shipping Service: Please provided your mailing address. (Peninsular & East Malaysia)
Facebook Page: Facebook.com/xdautoparts
Hi, im looking for springs n shocks for my forester sg9 sti. Do u have any products available?
Thnks
Quotation sent, thanks for inquiry XD-Autoparts =]
*Price might change without notification, kindly contact us thru SMS/Whatsapp 019 - 266 8138 or E-Mail [email protected] to know latest price, stock status or fast deal. Shipping service provided with extra charges, please send us your address.
