- Joined
- Oct 14, 2008
- Messages
- 1,915
- Points
- 1,638
Item(s): PENNZOIL PLATINUM SEMI SYNTHETIC BLEND SAE 10W-40 MOTOR OIL
Package includes: 1 bottle PENNZOIL SEMI SYNTHETIC MOTOR OIL
Price: RM75/nett
Dealing method: COD (Damansara, Bandar Utama, Kelana Jaya, Subang Jaya....)
Location of seller: Damansara
Contact method/details: 012-21 363 07 (Avin)
Item(s) conditions: Brand New & Sealed
Picture: As Per Attached
PENNZOIL SYNTHETIC BLEND SAE 10W-40 MOTOR OIL combines the strength of traditional Pennzoil motor oil, with a boost of Pennzoil Synthetic to provide protection against stress of heavier loads. It is fully compatible with all motor oils and can be used for all vehicles that require 10W-40 viscosity. It is specially formulated with time-released molecules to provide a sustained level of superior protection. PENNZOIL SYNTHETIC BLEND SAE 10W-40 MOTOR OIL passes the stringent requirement of Pennzoil and meets SAE International specification.
BENEFITS
Time-released molecules additives trap and remove the corrosive by-product of engine combustion.
Multigrade motor oil for excellent petrol and diesel engines protection.
Formulated using high quality base oil and additives.
Protects against harmful engine deposits and wear caused by severe service (high and low temperature severe service).
Provides extra protection against the formation of sludge during low temperature of short trip driving.
Provides extra protection against thermal breakdown of the oil and resultant deposits.
Helps keep engines running clean in the extreme temperatures created by harder working engines.
Assures the proper oil flow to maintain cooling capabilities.
RECOMMENDATIONS
PENNZOIL SYNTHETIC BLEND SAE 10W-40 MOTOR OIL is recommended for year round use in the passenger vehicles such as cars and multi purpose vehicles (MPV) wherever API SM/CF is required.
Exceeds API SM/CF Service Classification.
Can safely be used with confidence in any application calling for a 10W through 40 grade oil.
Always consult your owner’s manual for the correct viscosity choice.
Price: RM75/nett
BENEFITS
RECOMMENDATIONS
