{wts}sansui black diamond bd-a754
ICE -In Car Entertainment
lolx
Item(s):sansui black diamond 4 channel amp
Package includes:amp only
Price:rm450
Warranty:personal 1 week
Dealing method:cod or postage
Location of seller:kepong
Contact method/details:pm or call 0122103929
Age of item:below 1 years
BD-A754
4 Channel Mosfet. Bridgeable, 2 Ohm Stable Power Amplifier
· Variable bass EQ. control
· Driver delay II (2 second) control circuitry
· Thermal, short-circuit/overload protection systems
· 2 Ohm stereo stable/4 Ohm mono
· PWM mosfet supply
· Power & protection indicators
· 4-position selectable crossover (HP-LP-BP & FULL)
· Infinitely variable X-over point (50-650)/500-6.5K(x10)
· 12dB bass boost ® 45Hz (Switchable IWOUT)
· Crossover range selector switch (normal/x 10)
· Chrome terminal cosmetic-panel & RCA jacks
· Heavy-duty (bright) aluminum alloy-heatsink
· Soft turn-on/off (No "pop")
· High (speaker) or low (RCA) level inputs
· "Black Diamond" badge on the center of heatsink
Specifications
Maximum Power Output 300W x 4(1200W)
Power Output @ 2 Ohm RMS 140W x 4
Power Output @ 4 Ohm RMS 75W x 4
Bridged Power @ 4 Ohm RMS 140W x 2
THD@2Ohm Signal/Noise Ratio >92dB
Frequency Response ±1.0 dB 10Hz ~ 30kHz
HPF 500Hz ~ 6.5kHz
LPF 50Hz ~ 650Hz
Adjustable SensitivityRange 0.2v ~ 6v
Input Impedance (Low Level) 10k Ohms
Fuse 20A x 2
Dimension (WxHxDmm) 220x52x300
Item(s) conditions:look like new
Reason for sale:upgraded
