- Joined
- Nov 7, 2005
- Messages
- 922
- Points
- 5,018
HI ALL.. I have some items to let go.item may COD or courier. warranty, 1 week personal. prices are firm.Contact num 016 2510646
High Power:
2 x 25W @ 4 ohms
2 x 20W @ 2 ohms
2 x 100W @ 1 ohm
1 x 50W @ 8 ohms bridged
1 x 100W @ 4 ohms bridged
1 x 200W @ 2 ohms bridged
High Current:
2 x 12.55W @ 4 ohms
2 x 25W @ 2 ohms
2 x 50W @ 1 ohm
2 x 100W @ ½ ohm
1 x 25W @ 8 ohms bridged
1 x 50W @ 4 ohms bridged
1 x 100W @ 2 ohms bridged
1 x 200W @ 1 ohms bridged
Fuse: 20A
SOUNDSTREAM REFERENCE 200 (USED) RM400
Front Crossover Up to 4 way or 2/3/4way operation.
Sub 22-264Hz with subsonic 7-46Hz +/-10dB gain (This is always mono)
Midbass 56-492Hz
Midrange 80-1.7KHz
Highpass 80-7.4Khz
Rear crossover with rear fill level control
Midrange 80-1.77KHz
Highpass 80-7.4KHz
The pots actually have detents so they don't drift. There is also a -12dB input attenuation switch. You can set this crossover to take a 4 channel or 2 channel input.
Other specs
Frequency Response: 10-100kHz
S/N Ratio: 102dB
Dimensions: 10.4" x 5.125" x 1.81"
Supply Voltage: 10V-15V
THD: 0.02%
Maximum Output: 8V rms
Maximum Input: 12V rms
PRECISION POWER FRX-456 (NEW) RM650
PYLE MONOBLOCK (USED) RM400
BOSTON GS1200 12'' SUB RM360 ( WITHOUT BOX ) , RM500 ( WITH BOX )
MACROM 59.10 WITH TWEETER & CROSSOVER ( NEW ) RM750
12" ENCLOSURE .DESIGN FOR JLW7. NOT USING SINCE BUY. RM450 WITHOUT WOOFER
High Power:
2 x 25W @ 4 ohms
2 x 20W @ 2 ohms
2 x 100W @ 1 ohm
High Current:
2 x 12.55W @ 4 ohms
2 x 25W @ 2 ohms
2 x 50W @ 1 ohm
2 x 100W @ ½ ohm
Fuse: 20A
Midbass 56-492Hz
Midrange 80-1.7KHz
Highpass 80-7.4Khz
Midrange 80-1.77KHz
Highpass 80-7.4KHz
Other specs
S/N Ratio: 102dB
THD: 0.02%
