- Joined
- Jun 4, 2006
- Messages
- 2,798
- Points
- 1,683
lets see if i boost around 0.4bar, do i need an intercooler?
is it advisable to have the super charger full time running? even when the engine is idle...
lets say that i dun fabricate my own intake manifold, i force air into the IAFM intake manifold, is that even possible?
what are actually external injectors?
wat kind of oil does the sc unit needs?
Intercooler for 0.4bar actually not necessary... But cold air are denser... Thus, have more oxygen per volumetric. And colder air will reduce knocks possibility.
That's what i meant by connection. U do a pipe that joint the SC and the inlet manifold. But u need to relocate the throttle body to the inlet of the SC.
External injectors have to be controlled by injector controller. If's controlled via RPM and TPS parameter... Some piggyback has the ability to control external injectors... Example emanage.
Of course u can run upon engine start. Because the TB is located before the SC.
Just engine oil will do..
