- Joined
- Oct 27, 2005
- Messages
- 297
- Points
- 1,516
you r right.... absolutely right! but lucky enough that we have one here in sunway... hahah.. at least i find them good enough to be "one stop"...
zephuros said:Leme ask you guys simple question.... What is so different about an RB26 from other engines???
The answer: NOTHING! It's a simple in-line 6 that is over 20 years old. From a mechanical standpoint there is NOTHING different about rebuilding this block from rebuilding any other engine. The real question is, "Who is competent enough to rebuild an engine in Malaysia?"
Frankly, anyone who understands the reasons why we torque heads in a particular way, follow procedures for shimming lifters etc can and should be able to rebuild an engine perfectly well, including the RB26. This is not rocket science. What you do need to do is to ensure that you have the necessary tools and a clean envirronment in which to work. Also you need someone who is competent enough to bore a cylinder block and shot peen it!
With the right tools and work environment any tuner in malaysia should be able to build a decent engine for you. Here's the catch... we have all the tools.. we have all the facilitires... and we have all the brains.... problem is that all these are scattered among the workshops in the country! hahha! There is not a single shop in malaysia that has the collective knowledge.
