I just order a b16b engine kosong and plan to change the crankshaft and conrod to b18cr but use back the b16b pct piston. Will i have any reliability issue using pct piston or should i use b18cr piston?
the piston wont knock the valve or head?
Tat is wat I have....
[/I]Bro, with this build u can rev how high safely?
[/I]
I normally vtec till 9K.
Hv done max till 9.5K.
It's for daily drive..., no trouble.
Had it for 3 yrs oledi...
Since Shell stop the original V-power had to retard my timing a little due to "knocking" aka "ping".
Wow can rev till 9k + so high...Btw bro i got 2 more question.
1. Can i use back my spoon p2t(EK4) ecu + afc neo for this engine build?
2. How good is after market bearing( acl/king...) compare to oem?
Just curious, any increase of hp or not? Let say both using OEM parts :hmmmm:
B16b engine + b18cr stroker + b18cr intake manifold + b18cr 4-1 should be around same hp as 98+ b18cr engine. Hope my mec can tune it a lil bit more powerful then stock b18cr 98+ i already satisfy![]()
My goal is to get 200whp using oem cam and piston. I was thinking of upgrading stiffer valve spring + Retainer and also adjustable cam pulley to rev safely to 9k rpm. Any other recomendation???
