i got a unit of is250 high spec,mark levinson and come with gps and screen.
but may i know how to get download a malaysia map into this system??
it's only have uk map
Hi dude,
UK spec GPS run by dvd, Japan spec by HDD. Local spec also run by dvd, so what you can do is to get a copy of disc from local spec to try it out.
If you happen to get a copy of GPS disc from local spec lexus, pls share with me, hehe![]()
And me also.. :D Lathen, meaning mostly Jap spec run by HDD?
if not mistaken, i think all run by HDD. Even if u got the disc, also have to find a way to install / overwrite it
In long run, I would suggest to install flyaudio. It's using Papago where you can download the map from malfreemaps. My map is dated 01/05/2011.
how much u install flyaudio,i ask about rm4800 in setapak bubble motorsport
I've emailed to flyaudio dealer in malaysia,
They say flyaudio cannot work with Japan Spec, issit true?
alvincbw,how about your gps?oem head unit needed GPS DVD to run or not?
how you update the map
Alvin,
When you play cd audio can you still use your ML to play with it?
What about DVD? Using flyaudio?
Thanks
Thanks for the info alvin,
I am have a recon UK Navi unit c/w UK map which are useless to us.
I called Lexus Damansara , they have the CD Map for Msia and Sg....but they are not selling it to Recon Units...WTH...!!!
Anyone knows the ppl inside Lexus that might able to help us ?
