Kent also didn't reply my Post & SMS !!
This guy business style a bit strange, didn't welcome for call, only sms or email !!!!!!!!!
call him la buddy. easy. or go to his place.
he is a busy man.
If using standard absorbers which are long, paired with lower springs (short) will it work with full potential of the absorbers??
it's ok as long as the spring is not shorter than the absorber's stroke (spring had at least a bit of compression after installing the spring cap and mountings, before installing onto the car) is not longer than the spring.
Have some patience bro. I guess he could be busy as he have to
attend to a few cars in 1 day in his workshop. Try again, he does
pick up his calls..
I did fix a few items at his workshop adi..![]()
In that case, go to his shop is best.....![]()
Guys, any suggestion for the best absorber to match with Eibach Pro Kit spring?
every year need service for rm300 all stick?hehehe...no leak or leak also need service?expensive and waste money/powerful...make hot money i think they r..
I've read somewhere that the Prokit springs are best paired with Eibach shocks, but dunno where to get them. :hmmmm:
---------- Post added at 08:02 PM ---------- 6 hour anti-bump limit - Previous post was at 07:54 PM ----------
Are you referring to titan shocks?
Different category mah....some leak one absorber change one only......
Guys,
Anyone here has any experience using Eibach Pro-Kit sport spring? I'm interested in this product because it only lowers your car 1.3"-1.5" and claims that you still can use your stock absorber. The Eibach website also says that their spring is progressive type, which means it improves handling while still maintains close to stock ride comfort.
I went to a Michelin shop in Manjung yesterday and they quoted RM1500 per set! :hmmmm: I was very shocked as a set of GAB sport spring costs between RM500-600 only.
So, if anyone is using Eibach Pro-Kit or has experience using it, please share it here.. Thanks a lot!
Yes I knowww, im open minded. Like tanabe their coilovers cant be repaired, they said so themselves.
But nolah, you know. Typical Malaysian thinking all cheap cheap. RM300 for revalving so that it can perform at its best also say expensive.
Might as well go inject your standard absorbers with ATF and potong spring lah. Cheap what![]()
i using Eibach pro-kit for my new fiesta. in term of comfort, is almost like my stock fiesta. cornering improve 20-30%, feel more bite when turn-in corner. the lowering is just nice, not too low. i spend 1200 for the kit and 500+ europe spec front absorber(malaysia fiesta absorber is different from europe fiesta, so must buy front absorber to install). rm1700 i feel quite alot for the improvement .
