Big[V];3723897 said:For CVT, the ratio & change rate (up shift) is controlled by the TCM. In other words its the CVT that is pulling the car not the engine. If you have the paddle shift, at least you can lock the ratios at some point.
Big[V];3723897 said:If you come across a manual tranny for L15A, give it a thought; though it might not be cheap.
if so, that oso means changing to a manual would not only require a manual tranny (or any other honda tranny that wud bolt up to yur engine), but it prolly means you wud need a complete standalone installed as well. i reckon the removal of yur tcu wuld send myriads of error codes to yur ecu, no? that'll most prolly make it go into limp mode and stuff, hence the justification for the standalone.
you see how this is gonna be a lot more expensive than usual?
