mines998
Selamat Hari Raya folks.....
salam perkenalan bedebah! (lain macam je bunyi nye.. hehe)
anyway, u want the outside of the rim + tyre to be flush with the car's body rite?
so, based on my rim dimensions for the fitment.
i would say - front 8" offset 40-45 and rear 9" offset 40-45.
u can play around with the dimensions like with - front 7" offset 28-33
look HERE for wideness and offset play..
Hi! I can you guys help me to source 6A12TT complete wiring.
if ur car too low and it bumps, it will hit the inside of rear bumper (part with the nut/screw).with ur set up,does the rear tyre hit the fender on full load?
selamat hari raya to u too...Selamat hari raya aidilfitri, maaf zahir batin to all muslim v6 owner.
but u always can potong/skim a little bit of the rear bumper.
u have any rim in mind (with the measurements)?
Jein : you bought the car new and when you sent it to be serviced, they denied it was the GB problem which is causing the jerking but DIDNT fix the problem ? Did they say what the problem was then ?
When ur car Gegar, is it you feel the Body gegar, or steering wheel gegar , if u step on the pedal and change gear and the gegar hilang then it doesnt seems like a gearbox problem, feels more like the driveshaft to me.
Bad plugs , wires can cause jerking also.. but that feel is more like semput semput, doesnt feel like gegar or gearbox missing its gears or hunting gears. Its hard to diagnose your problems here bro. If able send your Perdana to a reliable work shop instead who knows what they are doing.
Hope your car sihat semula soon. Peace.
Oooo... memang nampak macam misfiring. I had this problem too bro.
Spark plug cable ada banyak jenis, paling baik kalo dapat yang memang ORI ORI for V6, jangan ambik aftermarket yang lain lain, bukan nak pijak cable yang lain, tapi enjin v6 ni sensitive sikit, dia punya manifold tutup 3 plug yang kat belakang tu, suhu kat ruang tertutup memang panas, takut cable lain... tak tahan lah. Proton punya "ori" v6 cable also buatan malaysia, kalo tak salah Rm250-Rm300.
Sekarang i pakai Ngk power cable, ori japan, lebih kurang Rm570. Settle.
Inilah pendadapat 2 kupang saya, tidak ada kena mengena dengan mana mana pihak haha :)
