yes. suspected DS causing the issue. or might as well your CV joint.
mayber your inner cv joint(gearbox side),normally happen during acceleration/tekan minyak,if outer cv joint happen during take corner(ktak ktak).
driveshaft consist of, inner cv(gearbox side) -- driveshaft -- outer cv(tyre side)
get recon one or check for grease or tolerance inside the cv joint.
manual?auto?gearbox,racing clutch also vibrate a bit or when clutch slipped.experience before.
if exedy 3 puck or 4 puck +heavy duty clutch the vibration only when release clutch.
in your case when tekan minyak or accelerate the most probabble is your inner cv.
how to check?no other choice other than have to dismantle the drive shaft and check for free play in the inner cv joint or no grease at all,try to rotate the cv joint when you pull the driveshaft out.most mechanic know how to check.check the cv cover as well.
based on experience,usually the knackered cv joint is on the reverse side of the vibration.let's say you experience vibration at left,the right one is the problematic one,sometimes can be both.
the easiest way is to get recon cv joint,and the knakered one send for recon and keep as spare parts.
u can recon your current cv joint/ driveshaft mine costs rm100 per side.
ok thanks all bros i will ask my mech to check....confirm nothing to do with the airflow or tuning right?
---------- Post added at 09:42 PM ---------- 6 hour anti-bump limit - Previous post was at 09:40 PM ----------
sorry bro what is CV?
sorry for replying late.
CV stands for constant velocity.
