Car vibrate when enter corner
Battle.Field
Hi guys,
I recently bump into this issue whereby when I enter a corner at 40kmh and above, I will feel a vibration. This happen only when I take a right corner. My drive shaft on left is a custom as I got my engine converter.
If I set my front camber to -1.5 and above, the I can feel the vibration even on the straight
If I set my front camber to as close to 0, I will only feel the vibration during left cornering
If I set my front camber to positive, no issue of vibration
Any1 of you have come across such problem? Driveshaft had been serviced... Do I need a longer/shorter shaft?
check bushing first..all bushings...
then set camber back again to negative...and then check alignment (toe to 0.0)
Thanks for the reply bro..
Bushing all in good condition and wheel bearing changed too. Toe to 0.0 .... ok ok... Will ask the mechanic to do it tmr. Thanks bro.
did u do something with your driveshaft recently? bcos if the driveshaft install back but not at the original position, it might vibrate on some speed..
It doesn't happen b4 this... Until i did a negative camber setting. Engine mounting just changed to those harden. It does help but the vibration still there. Ya, i m also suspecting that my driveshaft mite be too long or short.. Hhmm.. Any driveshaft specialist that i can refer to?
Guess the driveshaft really too long. The mechanic set my suspension for 2cm higher and I can hardly feel the vibration. Gotta get another piece of custom shaft soon.
Thank you for all your helps.
Did you lower the suspension? I had this problem when I lowered my suspension. Could be due to the angle the drive shaft is begin driven at. When I raise it back, no more vibration.:smokin:
localStorage.removeItem('xenFHideSidebar'); } }); }); $(document).ready(function () { 'use strict'; $('#gece-modu').on('click', function (e) { e.preventDefault(); $(document.documentElement).toggleClass('gece-modu'); if ($(document.documentElement).hasClass('gece-modu')) { localStorage.setItem('xenFDarkMode', true); $("meta[name='theme-color']").attr("content","#090909"); } else { localStorage.removeItem('xenFDarkMode'); $("meta[name='theme-color']").attr("content","#202020"); } }); }); $(document).ready(function () { 'use strict'; var aktifYukseklik, currentScrollTop = 0, header = $('#xenF-header'); $(window).scroll(function () { var scrollYukseklik = $(window).scrollTop(); var headerYukseklik = header.height(); currentScrollTop = scrollYukseklik; if (aktifYukseklik < currentScrollTop && scrollYukseklik > headerYukseklik + headerYukseklik) { header.addClass('slideUp'); } else if (aktifYukseklik > currentScrollTop && !(scrollYukseklik <= headerYukseklik)) { header.removeClass('slideUp'); } aktifYukseklik = currentScrollTop; }); }); $(window).scroll(function(){ if ($(this).scrollTop() > 50) { $('#xenF-header').addClass('headerShadow'); } else { $('#xenF-header').removeClass('headerShadow'); } });
