Battle.Field
Hi guys,
I recently bump into this issue whereby when I enter a corner at 40kmh and above, I will feel a vibration. This happen only when I take a right corner. My drive shaft on left is a custom as I got my engine converter.
If I set my front camber to -1.5 and above, the I can feel the vibration even on the straight
If I set my front camber to as close to 0, I will only feel the vibration during left cornering
If I set my front camber to positive, no issue of vibration
Any1 of you have come across such problem? Driveshaft had been serviced... Do I need a longer/shorter shaft?
