discuss Evo 3 800whp!! and above
E-V-O-M-I-V-E-C
So as title to achieve this target we got rm20k for item and workmanship to achieve
so we need a t51r turbo,FIC 850cc injector,eagle conrod and piston,tomei cam,adj cam pulley,banana(manifold),fuel railing-is this necessary?-
and i still need wat item?as my engine is completely stock :)
i think in order to be able to get that much power out of ur 4G63, ur management alone will prolly take up half ur budget
with 20K how is it possible to achieve 800whp? With just management and tuning already take up around half of it. How about internal? Handling wise?
wat management need 10k==
dont need motec lar bro..haltech e6x now only how much la..
thinking of getting piston and conrod as mention above :)
handling damn gd :D
althought nt 4wd but using r888 and 4 adjustable :)
not easy to get it. when getting such power, dont foget about drive shaft and gearbox as well. and the chassis can withstand the force?
Dude...If 20k can get 800whp......Imagine how many evo on the road nowadays with 1000whp!
you would definitely need more than 20k for 800whp
but you dont need a crazy amount either
just spend right the first time so that you dont have to upgrade again on that particular section
and spend wisely as well by getting the right equipment for your power goals and dont get anything that you know will not be sufficient in handling that power
if you are serious about this 800whp i wish you the best of luck and do keep us all here on ZTH updated about all the steps you have taken from day 1 if its not much hassle for you of course
as I think your build thread would be the talk of ZTH :biggrin:
Probably you need 4 - 5k for Engine management
Hardware - Stroker kit easily cost you RM14k
Turbo unit - Borge warner bull eyes - RM3 -5k
Aftermarket big plenum intake manifold - RM3k - 4k
Intercooler and piping - RM2k
misc = RM5k
DOGBOX GEAR SET - RM15k
Injector 2k cc = 2k
Just a share for your information approximately how much you need to spend for 600 -700 whp from a evo 8 upgrade which i witness the whole process
handling damn gd :D
first you need to hire something to totally remap the ECU, your haltech or motel
and before that, you need someone to rebuild the whole engine with new parts
2nd, to do that, wire/loom probably need to redo for good one.
in order to within 800whp, chassis need serious strengthen, links and joints need to upgrade
what about transmission system?
etc............
so 20k definitely not enough
If 20K is your budget and your target is 800WHP and above....sell your Evo and buy a oldskool/cheap body that can accept 1J/2J transplant.....then 20K for 800WHP is not impossible ~
Just my 2cent's,ignore it if i do offense you ~ =)
