jien1329
bosch supersport 0.8mm cable plug rm150 only im using it so far performance is good....
juniorkirk, upgrade tdo4 la wat else hehe...ctc sebastian....
alriteee huhu thanks :)
hye, i bought a new perdana, mmg kilang setting.. the gearbox dah jerking, lg2 bila nek bukit and drop to lower gear.. gear change not smooth.. masa dalam waranty, the proton always deny dat prob smpai habis waranty.. and now, the car like gegar when i drive at 70km/h.. when i step on the pedal and it changed gear, xde lagi gegar. spark plug tuka iridium dah. cable plug prob ke cmni? or ad lagi sbb lain? any views from forumer sgt dhargai since im a newbie here.,. huhu peacE!!!:proud:
it sounds like the gb is not healthy.Oooo... memang nampak macam misfiring. I had this problem too bro.
Spark plug cable ada banyak jenis, paling baik kalo dapat yang memang ORI ORI for V6, jangan ambik aftermarket yang lain lain, bukan nak pijak cable yang lain, tapi enjin v6 ni sensitive sikit, dia punya manifold tutup 3 plug yang kat belakang tu, suhu kat ruang tertutup memang panas, takut cable lain... tak tahan lah. Proton punya "ori" v6 cable also buatan malaysia, kalo tak salah Rm250-Rm300.
Sekarang i pakai Ngk power cable, ori japan, lebih kurang Rm570. Settle.
Inilah pendadapat 2 kupang saya, tidak ada kena mengena dengan mana mana pihak haha :)
if ur car too low and it bumps, it will hit the inside of rear bumper (part with the nut/screw).
but u always can potong/skim a little bit of the rear bumper.
u have any rim in mind (with the measurements)?
---------- Post added at 11:31 PM ---------- 6 hour anti-bump limit - Previous post was at 11:31 PM ----------
aiyo. u should have taken it. what rim model?found a set of 17" rim with 8"f & 9"r et35 all round. but scared it will sagat at the rear, so let it go.
ronaldet, i'll bring this up to the Vsixers committee and hopefully we can join this this.![]()
To fellow VSixers who wish to visit this event...
Kindly drop me a msg and i'll give out the details to u.
I can also arrange a slot for u guys if u wish to make it as a gathering day for your car teams/clubs.
U guys can get the chance to show off your "Precious Babes" and might win some cool prizes!! So what'ya waitin for?? :P
Itz FREE Admission....Comm'on and have some fun!! :P :thumbs:
yes! tak belah tak apa, janji hensem!!
if driveshaft bengkok, u will feel bergegar only and usually only during initial acceleration.
if misfiring, i think in all speeds also kereta semput2. timing rpm naik turun banyak. cuma obvious mase idling dan time betul2 laju je baru rase ok.
pastu tengok jugak grounding on the gearbox or pasang grounding baru with thicker cable directly connect to body.
kalo ko nak try ori punye plug cable, aku ade kat umah masih simpan lepas tukar enjin.
but since the symptom cannot be pinpointed directly, a test drive baru boleh agak ape problem..
btw, u bought the car new?
Could it be your TB giving problem?
sagat sikit je. if u skim the bumper a bit, no sagat la..
this is mine. not sure 35 or 32 offset
surely a great event it would be.. i mean the hypertune gt model search, yummy..
---------- Post added at 12:46 PM ---------- 6 hour anti-bump limit - Previous post was at 12:44 PM ----------
yess, i like.. forget what the other ppl say, and when u get tapau'ed.. janji hensem!!
yup looks first, my car not for race. tapau'ed oso no problem. TB=Timing belt? hehe noob sket
TB = throttle bodyTB=Timing belt? hehe noob sket
Yoko AVS model 5? first model or 2nd model? or the latest one model T5?yoko avs, the 5 spoke design.
saw ur pic before this. the rim are out of the fender thats why I thought it would sagat the fender. plus I always bring along my parents.
got link?
