our JPJ is totally useless and talk nonsense...
first time i heard this... how is it related?
cant see road one if u using cheap hid one...or just use white bulb...really cant see road during rain or wet hour at genting...
Opposite direction driver throws a 50 cents coin... Becos he cannot than...![]()
They see your bulb also already know lo. (unless your using projector la)
HIDs that doesn't come stock with the car is illegal no matter what color temperature, be it 10k/5k/4.3k its still illegal.
If you really want to install a HID kit, at least do it with a proper HID bi-xenon projector. At least you won't be causing glare to other drivers and you'll have a nice and even beam spread. HIDs retrofitted in a stock halogen reflector housing produces horrible beam patterns. With bi-xenon projectors, you have proper working hi-beams.
Glare is the problem with aftermarket HID kit. The glare shield that came with the kit is not properly made and most of those high Low kit in the market that uses halogen bulb for high beam is not the correct way of doing it. A properly high low kit are those magnetic type with a front cap over the HID bulb. Those clear lens that doesn't come with front light cap and fit in HID is the most killing one as there's no front cap to diffused off the light beam.
Also, I don't know whether any of you notice, those headlights that are not meant for HID after prolonged use of the HID, the top part of the reflector will become dull and the chrome paint will get cooked....most notable is the part nearest to the HID. Anyone have this before?
This should be post in the DIY HID ANTI Glare! Nice one Veloc
good DIY veloc. i used aluminium foil to glare shield my hellas in the past but used superglue to place it in place (H7...no place to screw). but damn good clean DIY u have there. very nice nails also...u go for pedicure ar?![]()
? And no, I don't mani or pedi.
