mines998
Bro you need to more specific how your car shaking. Any weird sound? Shaking at all speed?
forget to mention bro. both lower arm replaced with new one when i changed the drive shaft bro.. really confusing
one of my friend told me to check the front wheel rotors and did that too. still same. recently added centre hole also still same.
yep.
check tyre balancing and whether the tyre already bulging or rims are bengkok.
my car also vibrates @ 150kmh, which i suspect the balancing not good which i had not done anything to it. coz i'm a law-abiding citizen, follow speed limit.. hehe...
but i should say it should be tyre problem.. but in any special cases, your drive shaft could still be a problem... why? because it could be fitted too tight.. thus it has no play at all.. i experienced that before too..Salam and hello to all the V6ers out there. I just got myself a PV6 2002 last month and have read the forum from the beginning till the end. It has been very instrumental in my decision getting it even though a lot of people out there says that the PV6 is plagued with problems. I believe that it is quite a good car with a slight temperament.
My question to the Otai's and the Owners who have experienced it is, what would be the warning signs of your Auto GB going to be kaput? Is there things that you need to look out for so that you could be prepared (financially and time wise)? Or does the GB just go bust?
I do a lot of long distance travelling. From AS, Kedah all the way across to Kerteh, Terengganu and down to JB. Because as everyone always likes to say, prevention is better than cure.
