takut the fan not strong enuf.......
try to get a high speed fan....from kedai potong......better bring yr current motor as a sample....
last time my fren got 1 for me....he said from 6a13tt or pajero not sure...but its damn powerfull & slightly noisy too......night time water temp 1/4 only....
Else you might also want to check your gasket.. maybe slightly leaking..
for fan maybe this?
http://www.mudah.my/FORGED+RACING+USA+16+Inches+Racing+Radiator+Fan-13738030.htm
well i guess u can install it that way.Those fans are more suitable for front mount to blow instead of sucking..
just change the radiator fan - the fan on the right (driver side).and is it just 1 fan or 2? cause there are 2 fans at my radiator, so what do you guys recommend?
and if i get it from half cut, which model is fast , and how can i tell ?
if buy from halfcut, they will give everything like the fan on your car.when buying a new fan , motor not included?? if its not included, how much does a high powered motor cost?
yes, emanage improve's your FC & power. but u must have a good tuner to tune it le...
of course motul is better, but its too thin for my engine...im using shell helix semi syn now.
battery giving warning gonna kong.....or maybe just kurang batt water.
i did install m7 emcom (emanage) on my v6 .. gained about 7HP extra after tuned. have to agree that i feel a small diff on my ride.. bt the sad thing is that my v6 can go up to 180-19 only .. thats max .. with only 1 people inside .. using 17" rim only .. very sad on it ..
3rg gear .. 170 shift at 6.8K rpm to 4th gear that up to 180 only. RPM drop by 2.5K after shift .. any advice guys? btw do advice me a correct thread
car is auto btw
