Gab japan performance suspension
SuperVelocity
5,000 RPM
GAB® AVCS™ SYSTEM
What is AVCS™ system?
AVCS means AUTO VALVE CONTROL STABILIY
Where can we find AVCS™?
AVCS can only be found in latest GAB® Hilo Adjustable Absorbers.
What is the different between normal absorbers and AVCS®?
Most conventional absorber's suspension damping & rebound force is fixed. Stiff suspension works well on high speed driving and negotiating corners, offers maximum car handling but sacrifices comfort. on the other hand, soft suspension works well on bumpy road, potholes, and uneven road but sacrifices handling. Ever thought of obtaining a set of suspension, which can work very well on negotiating bumpy road, potholes, uneven road, high-speed corner with high speeding stability and comfort? Unless you opt for the very costly height and stiffness, adjustable absorbers, otherwise you won't be able to achieve the ideal drive handling and comfort. Or you can buy a few sets of suspension for all these road conditions to cope with it. To suit your driving style and road condition, you will need to adjust and tune the suspension all the time {even with the stiffness adjustable absorbers} wherever you need to change the setting. With GAB® AVCS, you don't need to do all these ever again!
How does AVCS™ work?
AVCS™ is the latest result of our constant R&D effort. With GAB® AVCS™ you can now feel the difference on uneven road, bumpy road, pothole, high-speed corners and highways. The damping and rebound force is automatically turned by AVCS™ to suit all road conditions. AVCS™ is an internal system that adjusts the stiffness of the suspension. It uses multiple layer valve spring to sense the road condition and automatically reduces or increases damping forces according to the road condition and your driving style. The latest technology of valve and internal spring mechanism enables the constant and automatic change of the comfort on all road condition without having to manually tune or adjust the absorbers.
With AVCS™ you just need to purchase one set of GAB® HILO adjustable absorbers, rather than buying a few sets of different suspension with different setting.
GAB® ADJUSTABLE SUSPENSION {WITH AVCS™ SYSTEM}
Suspension with variable height adjustment for better looks and enhanced technical features.
The art of gaining high speed performance
The ability to perfectly tune all the components of a suspension and adapt it to the carious types of cars and performance characteristics, creates a unique system that makes driving thats much more exciting while providing enhanced safety. Driving enthusiasts soon learn the art of getting the most out of the adjustable series shock absorbers from the GAB® adjustable suspension system. The threaded height adjustment along with the precisely defined damping settings, puts the full spectrum of advanced technology on the road. The result: greater performance in all driving situations through maximum road-holding and precise cornering.
GAB® SPORT LOWERED SPRING
. Enhanced the response speed
. Greater Road stability which gives
higher turning speed
. Reduces body roll and braking
distances for more safety
. Superb handling and stability ori
highways and cornering
. Sporty look and comfortable
Advance Technology Cold Forming
in contrast to hot forming where the spring is coiled at an elevated temperature, springs of our series are made through the technique of cold forming (normal temperature forming at a non elevated temperature). By using a dedicated new-type coiling machine, deterioration of the material is prevented and advance performance is retained.
GAB® SEMI ADJUSTABLE SUSPENSION {WITH AVCS™ SYSTEM}
Able to use back your sport spring or original spring.
Lower price and affordable compare to fully adjustable.
PROTON:
For Gen2/Waja/Wira1.6/Wira1.8/Putra/GTi
SS series: RM2800
HA series: RM1620
SA series: RM750
Lowered Spring: RM420
SA series + spring: RM1100
For Wira1.3/1.5
SS series: RM2800
HA series: RM1620
SA series: RM750
For Satria1.3/1.5
SS series: RM2800
HA series: RM1620
SA series: RM650
SA series + spring: RM1050
For Saga1.3/1.5
SA series: RM700
Lowered Spring: RM380
PERODUA
For Myvi
SS Series:RM2500
HA series: RM1520
SA series: RM750
Lowered Spring (30mm &45mm lowered): RM420
SA series + spring: RM1150
For Kelisa
HA series: RM1470
SA series: RM666
Lowered Spring: RM366
SA series + spring: RM1020
For Kenari
HA series: RM1470
SA series: RM666
Lowered Spring: RM388
SA series + spring: RM1040
For Kancil
HA series: RM1140
SA series: RM666
Lowered Spring: RM299
SA series + spring: RM950
Pillow Ball Mount Also Available
Proton
Mitsubishi
Honda
Nissan
Toyota
Daihatsu
Hyundai
1 year warranty for adjustable
1 year warranty for sport absorber
Many car model available, call to enquire your lovely ride and for the BEST PRICE!
If interested kindly contact or PM me for more information, location @ Subang Jaya
For COD purpose, deposit is require for ordering.
Credit card is accepted, PLEASE PM me for credit card usage.
Email : [email protected]
what is SS , HA , SA series? i just start learning about all this suspension thing.
how much for AE100/101/11/90/92
SS and HA series and can you please let me know the difference?
Thanks
hi, can pm me price for ss series for vios 09 including installation...thanks
