limsiaokia
Sifu out side there can recommend some engine oil brand 100% syn engine oil for Myvi? Thanks alot~!!
haha, how about 4A-GE?
>quote]
Budget? There's lots of fully syn oils out there. Helix Ultra, Pennzoil fully syn, Motul, Redline, Amsoil, Castrol Edge or Syntec, Ravenol, Royal Purple, Adnoc Image, Mobil1, Lucas, Liqui-Moly, etc etc.
Ultimately just choose a API-certified oil that suites your budget settle. And use the right engine weight oil.
if your myvi is 1.3 ,then you can use 10-30 but I used for my myvi but I feel the engine is not enough power..so today switch to 10-40...really better than that....
Why you said 10-30 no power when u used it?
it suppose are more lighter than 10-40 engine oil .. Well Have to check out the API arent the Oil certified by API - American Petroleum Institute http://eolcs.api.org/companySearchResults.aspx?mode=country&q=MALAYSIA
haha, then why the 10-40 engine oil is expensive than 10-30 engine oil......40 compare to 30 sure more power than that...
ic ic. If 300V then really not bad.
