- Joined
- May 21, 2004
- Messages
- 2,146
- Points
- 3,213
Ok here's the deal. I know nothing about the old school Mini but even less about the L2/L5 upgrades but currently babysitting a friend's Mini with an L2 conversion, Eterna turbo, Matspeed regrinded cams, E-Manage and some other odds and ends including a custom dash which is pretty wicked.
So I took it to Sepang the last track day but only did perhaps 4 laps in it (went in towards later part of the three hours because setting up Rev-Junkies retail booth, etc) and although the handling is pretty much like a go-kart, its really gymkhana rather than Sepang friendly.
Anyway, that aside I'd like to squeeze more power out of the car because as it is, the car is fine during the sharper corners but give it a little bit of straight say the stretch leading up to Turn 4 is enough to rub in how underpowered the car is to say nothing of the two straights.
Handling I think is a bit off perhaps due to weight? I don't know how much the L2 engine affects weight distribution but then again the rears have practically no suspension at all. Rock hard and definitely needs to be softer. But the main issue is perhaps slightly larger turbo? But how laggy would that be? Now engine revs fine, I try to not exceed 9000 but it does rev a bit too quickly at times and so far boost I've kept at 1 bar just to be safe.
What's a good turbo to upgrade from current Eterna stock turbine? I doubt I could get away with an FMIC due to space constraints so it'll have to be something that the top mount can cope with. Fueling I'm not too worried, if needs pump or extra injectors, surge tank etc all I have brand new spares. Other than that I don't see what else I can do to give it some extra power.
BTW, general rule of thumb - what's an L2 good for boost wise assuming tuned properly, enough fueling etc. How much can it handle? Also what sort of power are people putting out while still remaining somewhat driveable atm?
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash3/s720x720/525469_10151682687790360_503690359_23858045_895719118_n.jpg
