It is recommend by Michelin, GY and even Tire rack. If front less thread pattern and if loose traction (under steer), slowing down and can be controlled. If rear less pattern and loose traction (Over steer) very hard to control.
Check with your car club/model and ask in that forum what suspension is good. As you mentioned got many brands, therefore I can say, you will get reply saying this is good and that is good and you will further be more confused.
As far as I know, have done some lowering in earlier days, you cannot have comfort if the ride is lowered. You suspension travel is already less, and to prevent bottom out, the lowered springs used are harden or added spring rate, so sure the ride will be bumpier. Maybe getting those that can tune the spring and oil damping rate ones, then you have more option....
---------- Post added at 03:26 PM ---------- 6 hour anti-bump limit - Previous post was at 03:19 PM ----------
thanks bro.. will try asking myvi forums.. ride looks really high after intalling 17" wheels.. but i already can feel the loose of comfort compared to my stock wheels and tires.. but not that worst.. still goodi saw many recommend eibach pro-kit in many forums.. but quite high priced and most of the shops don't have it..
can anyone give a hint...thanks...
