quicksilver7
Balancing the crankshaft is kinda risky i think. Something goes wrong and the crankshaft can't be used? Not any workshop can do it lol. Please correct me if i'm wrong..
revving seems lighter a little bit or placebo effect.
But top speed remained the same. I used to have mythelogy LCP but it keep causing my steering belt to jump out even replacing the belt is the same. It happened especially sudden redline (downshift from 3 to 2) then the steering was so heavy![]()
Thanks for the usefull reply, any member use that on mivec or V6 engine? what is the result![]()
are ur other cars kelisa too? if not then no point comparing.
and yes its normal... my ex-kelisa behaves the same with the stock crank pulley
Will have to do mileagechange light weight crank pulley you will feel the car more pick-up, but top speed will drop little bit, this is my experience, but now i use back original crank pulley for safely. the story is here, firstly my friend use custom make light weight crank pulley in his eg8 single cam, after use for around one year the crank pulley crack, lucky in kl area, still can drive to workshop, and then he change a branded light weight crank pulley, but after some time, some thing happen, now he use back original crank pulley.
Hi everybody, good day to you all.
I would like to ask did any one here have
Lighted the crank pulley for Toyota Harrier 2.4G 2005?
Need some advise from u all expert.
I would like to know the effect and cost or after lighted, still
Need to install anything?
Your feed back is highly appreciate.
Thank you
Just read back the previous 13 pages mate. The answer is there. You can't expect people to spoon-feed you, gotta search for yourself.
Cheers
Thanks sifu, I got lot of info bout LCP but I didn't found any info or comment from harrier user about the
Experience after changing the LCP. Pls advise Tq so much and cheers...
No worries. To me, it doesn't matter Harrier or any other car, the effect will still be the same. But just curious, I don't rmb seeing LCP for the Harrier, where did you see it?
