3S-FE,GE,GTE Discussion/Gathering
gearbox st185 boleh lock tapi tak tahan lama .. berat lagi .. biasa pakai gearbox st171 je ..
hi guys, I'm just got my sw20 rev 2, notice that my car having fuel cut issue even with stock boost, how can I fix it? thx
kkyen,
at boost its cutting off?
Sentul63 & xMika,
Celica 4WD GBs are not designed to be locked to 2WD...that one is for TOWING purposes only
just sharing my experience...
ST171 GB which is Code S54 and i had it in my ST202 3SFE. have good shifting/acceleration but cant tahan lama if you abuse it
im using E153 from old Lexus ES300/Camry Solara, it has taller gears but not as fast as the S54 when it comes to fast shifting
my 2 cents
Hi all zth bro,I post behalf of my fren,we are looking for 3sgte turbo header for st205,newer gen that use map sensor,we tried old gen with maf sensor but the header won't fit...and the header I looking for is single outlet since my fren converting to single outlet turbo,do notify me where can find,thank you all..
kkyen,
ST171 gearbox is code S51 .. S54 not yet on the market that time until the celica/mr2 period ..
Thanks for the info! S51 was made for camry and solara not corona though...just checked Toyodiy (not sure how accurate)....corona used S50, S52 or S53
S54 is very similar to the corona Transmission
I believe SW20 MR2 3SFE 1990 was using S54..correct me if im wrong :biggrin:
---------- Post added at 04:39 AM ---------- 6 hour anti-bump limit - Previous post was at 04:37 AM ----------
whats you engine block? have you tried mudah? i rmbr seeing ST205 header for sale sometime ago
I also checked toyodiy, if says S50, 52 or 53 for corona gearbox then it is haha ...
Turbo MR2 uses E56 ... non-turbo uses S54 .. i think so
Hm... has not been updating the page for long time...
How guys doing? lolz
I would love to join this family of 3SGE.
But Need some suggestion from you guys. I drive a Corona (AT210) with 4AFE and planning for a engine swap with 3SGE. I want to know if I go for a sawp with 3SGE do I need to modify the suspensions to cope up with 3SGE's torque?
Hi bro, new prob appear, by the time i almost finish mount 3sgte, my windscreen crack, does anyone know where can i get st18x windscreen and the budget for them -_-"
how serious is the crack?? need 4 replacement depends on the seriousness of the crack....
