roooon
I want to reach 170whp on 1.6 block.
Any suggestions?
Any suggestions?
Try use
1) Camshaft Jun Type 2 spec (intake: 304 degree, 11.5mm lift)
-stock camshaft spec is (intake: 300 degree, 10mm lift),
-upgrading camshaft is a MUST for the biggest HP gaining in NA route.
2) Injector 275cc from Eterna TT @ pajero iO.
-stock injector is 240cc (not compulsory, need to check whether air fuel ratio is
sufficient with stock injector, 1 of my friends still remains stock injector and still
gaining 18xwhp from his 4g93 block)
3) Thinner Metal Head Gasket 0.4mm thick - Will raise up a bit compression ratio but
in return it will turn the engine easy to getting hotter. Advisable use the car for
weekend @ in town purpose only, dont take for long journey.
4) Extractor - Try use 4-1 custom extractor to get more gain on higher RPM since 1.6block is short
stroke rather than 4g93 block.
4) Management Microtech Lt-10s is the best for Mivec , or if you plan to use the car for daily use
perhaps to choose Haltech, much convenience on the road spec.
This is the biggest part to mod, not including Clucth set/etc.
Piston mivec, block, crankshaft keep remains for time being BUT trust me...after a while u will still need to change block into 4g93...the hunger for power will chasing u...hehe. Ive been through.![]()
Thank you sir for your suggestion.
so far I got a tri y header, CAI, exhaust VAFC, ITC.
Is the lt-10s a standalone ecu?
supposly you buy a black top 4g92 man, so your can is 180 no need to modified unless you want to become more powerful than stock engine.
Here is a picture of my car.
coz my front mirror let people broken already.
