Proton lah dude.
even with performance parts?
Cost wise, go for 4G92 MIVEC. If u insist on 4G13, then Bolt On will suit you. Even if u said "without turbo", it's pretty hard to achieve that 180HP barrier. Unless u bolted it. But again, reliability wise if u bolted it. Think about it.
If you send a lawnmower engine to any Japanese tuner to be built you think it can actually make power? :hmmmm:
4G13's have the worst things in the world to start modding with. Single cam, small displacement, a head that doesn't flow much air... But they are very very fun to rev even though they aren't that powerful.
---------- Post added at 01:29 PM ---------- 6 hour anti-bump limit - Previous post was at 01:28 PM ----------
You send your engine to anyone in the world they'll never get a streetable 180whp NA 4G13. Why is it unreliable after turboing btw? :hmmmm: What gives up first in the 4G13?
I attached a pix of my fren 100's HP 4Gs.Ya.. Thats good enough. I've a fren whose Iswara 4G13 already marked 100-105HP on the dyno. Thats good enough already.. To TS, if u targetting on number of HP for 4G13, its better be realistic. 180HP is about the size of Honda B18C GSR, 4G92 MIVEC and nearly the size of B16B R Type-R. It's better for u to mods as "sedap bawak".. Fun to drive, more torque and better handling. That's enough. You should look into better brakes system, nice set of tires, lightweight rims, better absorber, and a lil bit of UR chassis strengthening. I've been with Iswara before i switch to Honda. At least i can share u a bit.I attached a pix of my fren 100's HP 4Gs.
Cable tied everything. The sign of a true race enthusiast.![]()
| MONTH | DATE | START | END |
| JULY | 7 | 1800 |
