Unsacred8002
Hello all. A few questions.
Im driving an EG8 with B16A, spec 94. So now, since the mods i've done was only OpenPod, cables, plugs, exhaust and Crome chip, i actually have a few Type-R parts from CTR & ITR which i havent yet install. Right now, what i have in my stock is ITR 96 Spec IM+TB+Fuel Rail+Injector, CTR 99 Spec Fuel pump, ITR 98 Spec 4-1 OEM Header (Currently im on ITR 96 Spec 4-2-1), CTR 99 Spec 4-2-1 Header, and PCT ECU. My current setup is:
1. NGK R08 Cable+NGK Iridium BKR7EIX
2. ITR 96 4-2-1+2" pipe+mid bullet+RS-R Magic
3. 3" Rampipe+K&N Filter
4. Crome rechipped P30.
I've clocked 151HP from this mods, significantly increase from 140HP default reading. So, what i wanna ask now is:
1. If i do the IM swap, can i use ITR Injector? Its OBD-2 while my injector now is OBD-1. How can i use ITR injector on B16A?
2. If i do those IM swap+fuel rail+injector, is it necessary for me to swap the fuel pump too? Cause my friend told me that all the Type R value are diff e.g fuel pump pressure are higher than SiR, injector CC are higher than SiR. Cause im thinkin that, if i only change the injector without any upgrades similarly on Fuel Rail & Pump, it"ll hurt my car sooner or later (or did it?)
3. Since i have 3 headers now, which 1 do u guys think the best? CTR 4-2-1, ITR 4-1 or ITR 4-2-1? Planning to get Skunk2 Alpha in the future but i will get the header once i do the camswap.
So, can anybody share their opinion on this? Thanks.
Hi senior & knowledgable members ,
