Change to steel braided brake hose?
Everyone says its effective?
I need to change mine too.
I saw prices are rm300 but dunno is 1 set or what.
Steel braided does not increased the brake's bite rate but it works in the way you got no flexing on the hoses when you jam the brake, thus, make it more responsive. I actually DIY masking the stock brake hose using cable tight and it works just like steel braided. Only problem is its a plastic so it only lasted a few months.
RM2xx and above pricing are for 1 set consist of 4 braided hose line. You need to remove the wheels for installation.
so if u turn off u'r ignition key, the brake indicator will not give out signal to turn on u'r brake light unless u set u'r key on acc position, now the problem is, when u r goin to park, surely u will press the brake & brake lights is on, when u pull u'r e-brake, ur foot is still on the pedal,once the indicator lights is on, another power will go to the brake bulb, would it be a surge to the bulb & burn it, thats is what i'm trying to unlock:hmmmm: what do u think @ sifuses out there
check engine signal continues...
