Ok can you please take a closer picture and show it here once more?
https://it1fuq.sn2.livefilestore.com/y2pn6FnmvcPawPUFNbB-uphBO606uaeEeG-q71ChRM4toWKa_Cbxq0Su-Db6Ur35HKuZw_k48Aqe1AfSFE9xEK4MMOrdutRfa8Cdv1MQFyb3VkgwHVyeJTLY0kk6R0FWVJB/WP_000783.jpg?psid=1
I'm gonna go swap my 1/4W resistor with 2W then I'm done. 1 step closer!
By using this http://led.linear1.org/led.wiz ,
13V source, 2.8 forward V and 20mA, it came out with 4 Leds to a 100ohm 1/4W resistor.
Why is the wizard giving me that answer ah?
This is my spec sheet btw. No wattage value. I don't know how to count so I rely on calculators, manatau its wrong.
stupidcar, I can't see your image la...also you no need to 100% follow the site give you the W.
If you follow the web site suggestion, you can use 100ohm 1/4W resistor.
The reason i suggest you to change it to 2W is because i assumed you connect the LED in parallel.
Stupidcar, you read the website suggestion carefully.
Pick from website
the wizard thinks 1/4W resistors are fine for your application
Also pick from the ? mark
Resistor power rating
The wizard uses your drive current to calculate the power dissipated in the array resistors. Standard resistors are available in 1/8W, 1/4W, 1/2W and 1W, and some values are available above that. The wizard picks a resistor wattage for you based on the guideline of operating at less than 60% of the rated power.
W in resistor is the power rating of the resistor. In other words, after you have designed your circuit, you look at the selected resistors, and you calculate the power dissipated (I) Power = current x voltage (P=V/R, or P= V2 /R or P= I2 x R- you MUST select resistors with a power rating that exceeds the result.
Stupidcar, I just worked out a wiring diagram for you. You can test it out. My spec is like below. I use 14V as engine started the Voltage is about that range. You can use 100 Ohm resistor @ 1W. Calculated actual Ohm is 82 but I go higher for safety. You can try 110 Ohm also but LED less bright.
Vs = 14V
LED = 3v
Current = 25mA
Stupidcar, just helping out fellow forummers here....next time belanaj me teh tarik la...Muahahaha
Must be a really good cup of teh tarik for you to come up from the south.....![]()
It's big already what.
Bro., I am not into electronics and I know that is the driver they were talking about, because connection is brake light with tail light function.....![]()
Without them can function? hahaha
Oh ya, the black thing is what?
I'm reading back everything.
And if without the black thing. Will it short it when both side are on?![]()
That black thing is a diode. It controls the flow of electrons so it doesn't go back. I would say without the diode there'll be a short circuit everytime your brakes go on.
Light emitting diode haha LED is a diode tooLight emitting diode haha
cabut !
cabut !
Yeah. What diode dei.
u can sell this item to me.(will consider the...
