i notice that R32 disc brake can fit in 15" rims.. if im not mistaken i even saw some photo shows kancil with 4 pot from R32 also with 15" rim.. So, i'm very sure it can fit 15" rim. just make sure that u may need spacer to clear off some offset. maybe u can scrape off the nissan logo and paint it blue like spoon 4 pot.. hehe..![]()
thats when theyre paired with 282mm rotors... i already know of the r32 calipers + 282mm rotor combo...have a friend who runs this setup. the stock 296mm rotor wont fit under 15"
im just curious as to this toyota caliper... and whether it would be possible... hence kinda need to know how much diff in size these calipers are....
how bout u do some research on s14 4 pot kit?
no need research... i actually own a pair of the calipers hahahahah... but missing a hard-to-find part
besides, these toyota calipers are much more easily available for a cheaper price compared to the nissans. so just wondering about the posibilities.
I guess toyota can't fit too small disc.. as mine already fitted to 16" super tight clearance without balancing metal on the rim.. lol..![]()
here some poison photos... heheh
there are one hassle free way actually,using evo 5 or 6 brembo, pnp, just need change the caliper bracket bolt since the brembo using is either smaller or bigger 1mm bolt then your oem twinpot caliper(i assume u are airtrek turbo)....not as painful to you as modding toyota caliper to your airtrek ,but painful to your wallet![]()
:driver...
