Where to get custom made Heat shield in KL area?
yewly1990
Does anyone had idea where to custom made Heat shield in KL and selangor area, I had been quote to exhaust shop, but most of them refuse to do so.
proceed to atmosphere motorsport in sunway and find eric (0197537738).
good luck.
can find those kedai ketuk/mudguard shop as long they have a metal sheet & a welding tool should be able to do the job.
but better u cut out a template of your heat shield on a pc of cardboard, easier for the person to just cut it out on a metal sheet
& weld it.
good luck.
Thx for the contact number, greatly tanksful
---------- Post added at 03:08 PM ---------- 6 hour anti-bump limit - Previous post was at 02:59 PM ----------
& weld it.
I waitting for the intake installation, cause most ppl said that soaking heat air will causing fc problem, so I planed to do short ram intake which away the heat air area, and custom a heat shield to reduce even more heat air.
---------- Post added at 03:10 PM ---------- 6 hour anti-bump limit - Previous post was at 03:08 PM ----------
and dont forget to post one when u get good deal.. we might follow your step..
Hell yes bro, I will do so.
whre is gme racing located?r they familiar wif rb engines?
GME Racing is in Kuang... http://www.gmeracing.com.my/
top notch stuff they make
can also look at Undersix exhaust in sunway
