Bad smells from exhaust (especially cold start)
desmond0318
Hi guys, i hope to get some opinion before i get chopped few thousands..
If this bad smells happens on your car, which one would you do first:
A: It came out from the exhaust, there might be a leak or something clogged, i should go to exhaust shop.
B: I should go for repair workshop for a TB and intake manifold cleaning. Cause the smells is similar with a WD4D burning, and few years ago there's really a mech did a WD4D clean into my TB without taking the TB out.
C: Try diy change something related with fuel hose example charcoal canister, some ppl said this must be change every 60k of mileage but really not much ppl notice this things is needed for automotive service.
Description of bad smell: Smells like WD4D+petrol burning together, if im facing to the exhaust tip distance about 1ft for cold start, i will imediately feel pain in the eyes that struggle to open my eyes and sore throat if breathing in.
I must get this fix because is killing my family :banghead:
Hope you guys guide me which should i go for first :idea:
After cold? Most cars have the smell when its cold.
I think its because its warming up with richer fuel.
And I told its normal.
My hse's Innova and Persona.
i felt something was not right because last time using ron97 it dosen't have those smells, i mean that smells really make ppl sick 1, sometimes i felt dizzy :puke: Hope it's normal as you said bro :biggrin:
What have you done for your car bro? What spark plugs are you using? I know your car is a VDO like mine.
Bro Izso, my exhaust system and injector stock for 10years already, injector still original but i saw the spark plugs seems like running rich with ngk's heat rage '5'. If i use copper plug, it will be more smelly than using platinium :bird:
Im a little bit consider for 'B' at the first, but my neighbour have the same car smells the same at the morning so im confused. Charcoal canister also never touch it for 10years, im not sure would that related to bad smells :banghead:
It only happen on cold start, it smells normal after the engine and exhaust hot enough until no more vapor water out from the tail tip..
I would start with the charcoal canister first. 10 years is too long!
What is the service life of charcoal canister? Many don't realize its existence including me.
haha yea, but really never ever mention by any mech that need to be replace. Bro Izso when you free can to pop up the hood can you check how many hose on your canister? Mine got 3 hole but only using 2 hose, lefted want free play without hose, wonder is it missing or it was like that since start.
Million of thanks bro Izso :knuddel:
---------- Post added at 09:14 AM ---------- 6 hour anti-bump limit - Previous post was at 09:13 AM ----------
I've searched some info from google it said 60k km >.<
Firstly, like bro. S.car mentioned could be richer fuel for cold start, so petrol not totally burnt off.
Secondly you mentioned smell like WD40 and that is oil, so could be some engine oil dripping in from valve guide. After initial burn off and when engine is hot no more smell....
Bro vr, i've checked the oil level every week or twice a week no oil missing. Maybe i have phobia for that TB clean with WD4D that mech did last time, keep pop ups in my mind that if WD4D sticked at intake manifold will that smell disappear after came out from the combustion chamber?
If it's really running rich, what should i do?
The leak in valve guide is very very little only, not as in consuming engine oil, then your car will be smoking already...:biggrin:
Morning running rich is normal for cold start, just as long as when heated up should not run rich...:driver:
I have almost the same problem recently. I was waiting in the car for my gf, and my engine was running as well.
So, when I leave my driver door open, I can smell the exhaust smell, I can't explain how it smells like but then the smell is just
unbearable. I'm afraid if there is a leak somewhere but during acceleration is fine an quiet. Just engine roaring sound.
If i stand around my car outside, I can definitely smell the exhaust smell and can feel some heat when I stand beside my driver side car door and front tyre.
My friend told me once before that is quite hot in front when u bend down at the front tyres when engine is running. No white smoke,
just exhaust smell is strong. I thought of getting it check this saturday as well.
hehe, hope no big deal la.. wallet getting thinner nowadays everything's increased :biggrin:
Valve guide oil leak is very normal for older engines...very minimal also...
---------- Post added at 10:38 AM ---------- 6 hour anti-bump limit - Previous post was at 10:37 AM ----------
It will be hot in front when radiator fan is on...:biggrin:
Ya was wondering, cuz friend told me something is not right how come ur car so hot around the tyre area :biggrin:
But now exhaust smell i really dunno what is the problem. U say if stand behind can smell then quite norm to me, but then even when Im in front then smell is too strong.
sometimes, when car left not running for quite a while it may smells bad during warm up.. it is because of petrol build up at along the hose..
My car everyday use mia :rofl: and that time the car already warm up quite some time and i stop at the side waiting for gf.
don't know y but my kelisa engine bay oso getting hotter not like in 5 years ago, that time after long hours in jam can open the hood locking mechanism without much heat, now it's very2 hot, even the hood holder oso hot like wtf:banghead:. than my kancil exhaust smell oso got into the cabin but than again i think it's normal coz runnin wit no a-con & windows down. problem is if on the run the smell oso very strong even wit all the wind around. if only can do test to see where the fume came from like those heat vision thingy where different temp shows different colors. i wonder hmmmm:confused:
