Am back after after a long time. Previous my ecu ic was burned. Thanks to some help from zth sifus. In the end I bypass the issue. Lol for time being. Till I change the engine. However I am looking for this items not sure what bumper is this can anyone help me pls. Can this fit into my 1996 ae111 local body ?
AE92 TRD strutbar
Kakimoto chambered muffler
4age 20v toda flywheel
4age 20v clutch set need not new as long as above 85%
tanabe df210 ae101/ae111 lowering springs
tanabe precede superdown ae101/ae111 lowering springs
shop to fix meter wiring, install sandwich plate and wire oil pressure to GT gauge, replace flywheel and clutch and find gear oil leak
Looking for ae92 4agze map sensor version complete engine wiring ecu fuse box etc,cam sensor,coil,stock 4agze injector,anyone have it do sms/call/whatsapp fai 0168309341,Thank you
AE92 TRD strutbar
4AGE 20V Blacktop MT or AT ECU 4pcs needed budget 450RM each
AE92 TRD strutbar
Oil Pressure sensor that will work with AE92 Long meter
Double layer brake servo
AE101 Roofcut with sunroof complete
This is a table of turbocharger data that I have collected over the years. It will help guide you select a good turbo for your car. The best turbocharger upgrade for anyone who wants a powerful...
Hello 2 those who can help me out with my Kancil turbo problem.
I'm using a standard Mira turbo EFI engine on my Kancil. My idling rpm is unstable and giving a sound like a naval attack boat. It's so irritating to...
