Tuning my Airtrek
stutzedward
Well, it has been ages since I talk about tuning my car. I did ones when my HKS bov kept stalling my car. That was when the car was completely stock with only boost controller, intercooler piping and de-catted. Speed cut was also removed that time.
Over 3 years now, it's time for tuning again after I've changed some engine hardware.
1) FMIC
2) Evo 6 Cams & Valve Springs
3) Evo 7 TD05 Turbo
4) Evo 9 MR Injectors
5) Works Fuel Regulator
6) Walbro Fuel Pump
7) Straight flow N1 exhaust
At first dyno run, I had a shock to see the figures. - 155whp & 241Nm @ 0.8bar. C'mon, it can't be worse than a stock Airtrek. Stock can see around 160-170whp. That is why every engines are different in a way. Engine health is really important.
Soon after investigating further, we found 2 issues.
Petrol! By all means, do not use SHELL petrols. They're horrible. Professional tuners at GT Auto (Thomas) & AC Motorsports Lau said Shell petrols are the worst fuel in the market. In order to prevent it from drying up under hot sun (our climate), they added lotsa addictive making it vaporising slower than other petrol. That also means it has somewhat lowered the Ron. I believed it's somewhere around 93 for the 95 they're selling. I refueled 95 for tuning.
Secondly are the plugs. Mine was really bad and I didn't realize at all. :(
So here are the incremental progress.
1) With some air-fuel adjustment + fuel regulator tweaking, it went up to 180whp.
2) Then replacing the bad plugs. It jumped a shocking 21whp to 201whp! Check your plugs guys.
3) So in a bottle of Octane booster to push it to a true 97 + fine tuning, the final result was 241whp & 332Nm wtq.
That is a 86whp & 91wtq improvement. Much like adding a Vios into my 4G63T.
After all the hard revving during tuning, my fuel hardly went down much as compared to my daily driving. To my surprise, it saves a lot more fuel even after heavy footing it so many times. We dyno-ran my car for 35 times.
I wanted to boost it at 1.5 bar but it max out at only 1.2. This is due to weak actuator. I need an external wastegate I guess. That's the next thing to do. If I am able to reach 1.5 bar, I can easily achieve more than 260whp.
attachment.php
UPDATE
A few things I noticed different.
1) On morning start up, RPM is much lower. I can't drive immediately when engine is cold, it will jerk. After it's warmed up, everything is ok.
2) Water temperature is lower than half mark during morning driving. Usually it will be at half mark after I idled and never comes down again. Once driven, it will lower again. Maybe engine is running much efficient now, hence less heat?
3) During idle, vacuum is -0.15 bar instead of 0.5 bar last time. Not sure if this is normal but fuel is guage is coming down a lot slower now.
UPDATE
Problem 3 resolved. Idle now is -0.5 bar. It was due to leaky vacuum pipe.
If you want more details, you can PM me or just call our God of Airtrek, Ah Wah @ +6012-296-3909
Wow - Really nice results there. You have inspired me with my own project. I am still collecting parts before my build but so far have:
Evo Vii GTA Turbo + Lines
Evo Vii Manifold and dump pipe
Evo Vii FMIC
Sti Pink Injectors
Evo 9 metal BOV
Tactrix Openport 2.0
Just need a few nuts and bolts and some piping for inter-cooler
Great job! You think the evo 6 cams much gain?
Evo Vii FMIC
Sti Pink Injectors
Evo 9 metal BOV
Evo 8MR turbo is also a good option or stock evo 7, lag isn't too bad really. Also recommended is good exhaust and front pipe 3", otherwise you will get restrictions on flow like i have currently.
You in Auckland?
Bro Poacher, evo 6 cam improvement was obvious. I shared here last time. :driver:
That is a 86whp & 91wtq improvement. Much like adding a Vios into my 4G63T... LOL
i think not much of a different as i done some research on the net. found out in tomei web has several engine's cam profile. so in the figure, starting from evo6 above the profile is 260deg and 10mm lift. evo5 and below has 252deg and 9.5mm lift. that is what they state for stock cams figure... correct me if im wrong.
---------- Post added at 10:22 AM ---------- 6 hour anti-bump limit - Previous post was at 10:06 AM ----------
its a good figure of torque for that much of mod.. bravo.. :driver:
You in Auckland?
Yeah bro I'm in central Akl. Had a chance to get my turbo for cheap (200 bucks) so took it. Will do exhaust eventually I guess, already got a JDM/jasma backbox that was on the car when i bought it.
I fueled Shell Ron 95 and that's the worst fuel from producing power perspective. Advised to use Petron or Petronas.
my cousin currently a chemist working with petronas malacca. he did mention that petronas fuel after finish process is normally more than RON95, actual RON96+- due to lack of burning power here in their plant. but recently they did do some construction to park bigger tanker at their jetty for their burning gas. just sharing some infos.
---------- Post added at 06:21 PM ---------- 6 hour anti-bump limit - Previous post was at 06:19 PM ----------
call ah wah just now and he mention it took halfday work to install the cam. hopefully it went well.
Hope your cam installation went well. Did you tell Ah Wah that I introduced?
I only dislike Petronas because they don't accept Amex card. I once can't find any petrol station and only found Petronas, so I forcefully refueled and felt the difference almost immediately.
yup. i tell ah wah that edward is my bos.. hahah.. if this afternoon im free, i'll drive to ah wah to install.
He dunno me as Edward wor.. hahaha... just tell him the secret code I told you in my PM. Shhh....
hahah.. will do bro...
bro, u mentioned octane booster on last post. is it prestone octane booster or other brand? is this brand ok?
Honestly I was too excited to see the dyno result, so I didn't realize what octane booster was poured into my car's fuel tank. Hahaha...
