[Toyota] Looking for parts ? - Post here !!!
bosss looking for this item
distributor (4-cable & cover)
car: Corona
year 1990
model st171(3sfe)
Looking for Levin Carpet
Looking for
AE92 TRD strutbar
Kakimoto chambered muffler
toda flywheel
clutch set
tanabe df210 ae101/ae111 lowering springs
tanabe precede superdown ae101/ae111 lowering springs
sms/whatsapp/viber 0176976371
Hi, i got ae101 4agz ecu areadly rebuild condition and test respon goood. Wesapp 6591289539..
i looking jzx100 mark II rear bumper with lips
and rear light set....
my contact : KOH 012-2685516
Hi guys.
Am back after after a long time. Previous my ecu ic was burned. Thanks to some help from zth sifus. In the end I bypass the issue. Lol for time being. Till I change the engine. However I am looking for this items not sure what bumper is this can anyone help me pls. Can this fit into my 1996 ae111 local body ?
Thanks a million
Fresh.com
Looking for
AE92 TRD strutbar
4age 20v toda flywheel
4age 20v clutch set need not new as long as above 85%
shop to fix meter wiring, install sandwich plate and wire oil pressure to GT gauge, replace flywheel and clutch and find gear oil leak
Looking for ae92 4agze map sensor version complete engine wiring ecu fuse box etc,cam sensor,coil,stock 4agze injector,anyone have it do sms/call/whatsapp fai 0168309341,Thank you
Looking for
AE92 TRD strutbar
4AGE 20V Blacktop MT or AT ECU 4pcs needed budget 450RM each
looking for
-toyota altis gen9 used skirting & bodykit
-Fgk fujitsubo 2inch inlet 3-3.2inch outlet s-flow muffler
-Tanabe Hyper Medalion 2inch inlet 3-3.2inch outlet s-flow muffler
Looking for
AE92 TRD strutbar
Oil Pressure sensor that will work with AE92 Long meter
Double layer brake servo
AE101 Roofcut with sunroof complete
Re: Toyota Marketplace Links V2
looking for 1 set (left & right) seat belts/safety belts for toyota AE111 year 97.
