- Joined
- Mar 21, 2009
- Messages
- 36
- Points
- 1,508
I jus converted front and rear brake disk for my car on EJ6 chassis. But after the conversion the ABS warning lights up.
The half cut was from EK ViRS together with ABS sensor. Initially i only intended to convert the rear drum brake but i notice the the diameter of front disk and brake caliper piston are 1.5 inch bigger, thus i convert all together.
Are the ABS sensor from EK ViRS and EJ6 the same? When I plug in LAUNCH machine it reads out there's open circuit on all ABS sensors
What seems to be the problem? Enlighten me please....
p/s:- After conversion the braking force is superb only that the ABS is not functioning
