u can buy the power window panel instead of individual switch. if your perdana is 02 & above it wont be able to use the eterna ones.
only 95-01 model.
only 95-01 model.
i encounter this too and i have no reverse light for more than a year already. huhu..need some help, my perdana v6 no reverse light... my mech say hard to fix as the sensor is in the gearbox. Anyone encountered this before?
i more kiasu and kiasi..
i actually install 2 led light at the undercarriage of the rear.. 2 pcs each side..
so when i reverse, they will shine onto the floor..
well, you know the lighting in our road..
sometime can be real dark and next, is the drain...
but i always make own loud sound like "BEEP BEEP BEEP" if there are ppl there to warn them im reversing... kikiki..me 6 years no reverse light, since bought till sold the car hehe...
but i always make own loud sound like "BEEP BEEP BEEP" if there are ppl there to warn them im reversing... kikiki..![]()
Thanks bro ... last night "Sharing - Tips" @ Mohsin TTDI
hello Danz,
wanna ask.
for V6, we only need to change the timing belt?
is there anything else that need to change?
Hi Danz,
Thanks for your input, that means MYR690 is a good price mark. Wah 8 hours?! didnt expect to be that long...btw u mind sharing any workshop that has expertise in pv6?
while u at it I suggest to change water pump, spark plugs & plug cable, at least u save on workmanship. to change water pump alone will costs u the same for changing timing belt, same goes for the plugs & cables.
