Perdana V6 Community Forum *
u can buy the power window panel instead of individual switch. if your perdana is 02 & above it wont be able to use the eterna ones.
only 95-01 model.
need some help, my perdana v6 no reverse light... my mech say hard to fix as the sensor is in the gearbox. Anyone encountered this before?
i encounter this too and i have no reverse light for more than a year already. huhu..
Pro no need reverse light to warn other driver :driver:
hahahaha..
anyway updates on the light..after try and error etc.. :proud:
i more kiasu and kiasi..
i actually install 2 led light at the undercarriage of the rear.. 2 pcs each side..
so when i reverse, they will shine onto the floor..
well, you know the lighting in our road..
sometime can be real dark and next, is the drain...
the advantages of using the 1st versioni v6 bodykit..the reverse lamp are quite low and lights up the ground
Hi Guys,
Need your kind advise on reputable workshop for timing belt and spark plug change for pv6, and of course with acceptable charges. Currently I am clueless on where to go, i've search around and got quoted different amount of labour and parts price:
1 workshop in S.Alam quoted: MYR 880 for timing belt and water pump include labour
Item: (MMC belt with all seals and bearings) (GMB Waterpump)
Duration: (will take 4-5 Hours)
1 workshop in bangi quoted: MYR 690 for timing belt change with waterpump and labour
Item: (MMC belt with all seals and bearings) (GMBWaterpump)
Duration:(will take almost whole day to complete the job)
Im not sure why the prices varies that much, and as for the spark plug change, quoted MYR 100 for labour and MYR 270 for 6 plugs of denso iridium ik20.
I need your opinion on this price quoted and the parts listed, is there any other brand of timing belt to consider to? like dayco or gates? and water pump is GMB or Aisin?
Your advise is very much appreciated guys!
if not mistaken the price for dayco timing belt rm270, GMb water pump Rm130, workmanship bout rm250-300 depending on workshop.
mine took 8 hrs to complete the job.
Hi Danz,
Thanks for your input, that means MYR690 is a good price mark. Wah 8 hours?! didnt expect to be that long...btw u mind sharing any workshop that has expertise in pv6?
hello Danz,
wanna ask.
for V6, we only need to change the timing belt?
is there anything else that need to change?
hello Danz,
wanna ask.
while u at it I suggest to change water pump, spark plugs & plug cable, at least u save on workmanship. to change water pump alone will costs u the same for changing timing belt, same goes for the plugs & cables.
---------- Post added at 11:56 AM ---------- 6 hour anti-bump limit - Previous post was at 11:55 AM ----------
Hi Danz,
duration will be from 6-8 hrs depending how busy is your mechanic.
my previous workshop did a very good job on my engine, but sadly I made him bankrupt & closed shop because he took my car for a ride & had an accident.
I advice find a workshop close to your home at least its convenient.
noted on water pump.
spark plug, i'm on iridium.
is there a need to change plug cable? i thought if it aren't spoil, don't bother.
what about fan belt? is there a need?
V6, run how many belt in total?
my savvy runs on 3 belt, engine, aircon, radiator if i got it correctly
Hi you guys have any idea how much it costs to do top overhaul and full overhaul?
A brand new v6 engine I heard was rm4,000.
it depends on the brand of the top/full overhaul set,
top set from japan bout rm160++
full set from japan rm250++
during the process u might replace wear & tear parts therefore budget less than rm700 for top overhaul & less than rm2k for full overhaul
that is an estimate price.
workmanship depending on mechanic
