i have no experience in unichip.. but i heard the tuning quite detail.. last time i only uses e-manage M7. try ask papagoines..
i'm no sifu lahhhh...
---------- Post added at 10:28 AM ---------- 6 hour anti-bump limit - Previous post was at 10:26 AM ----------
BTW, better get ur radiator circulation checked.. i saw ur water temp is already 50%.. it should be around 45%.. go get ur radiator serviced and check ur water pump..
Id probably tap the unit myself... hopefully im competent
yeah it should be good enuf since ur not hardcorely mod ur engine.. some guys at SNF also uses SAFC for their kancil..
---------- Post added at 11:07 AM ---------- 6 hour anti-bump limit - Previous post was at 11:06 AM ----------
makesure u have all the required diagram and all.. goodluck dude.. share some infos here ok..
Parts obtained so far.
Walbro 255 fuel pump
Turbosmart Compgate 38mm
FRP 450x180x56 Intercooler (tube & fin)
Detomaso injectors
Coming soon..
TD04-09B
Tomei Fuel Regulator
Unichip Q...
Broke :(
since you are doing turbo, waste gate and front mount, are you going to put in banana exhaust manifold too?
btw any sifu here know the spec of original l2 injector how much cc??
