My Perodua Kancil : Chromaworks Sidewinder
Hahah yeah. Having some headaches trying to center the output hole on the manifold and the input side of the turbo. Bolt overlapping. Well decided to weld in a new adapter of the manifold to make it permanently take td04.
On the wastegate the problem seem to be worse than i tot.. the gate is on the internal side of the housing and the output side is shared with the exhaust.. nothing i cant settle tho, ill be fillinf in the cavity and remachine the housing so the exhaust and wastegate side is isolated. On the EWG its gonna be mounted real close to the rad..
hey bro congrats on the revival of the project! Hope to see some mad updates soon :wavey:
Kobzng. Thanks bro..
DanzEterna. Haha kancil was offline for 2 years bro.. was playing with my other car.hhehe
. thanks for the compliment bro..
Starkiller.. wah now riding Merc d... what happened to your neo bro? Still keeping that beast?
Knowing how your Mousedeer looks so awesome, I dare not bring my mousedeer near yours during TT :rofl:
Very nice. U may not like ready made JDM Mira Kits, but your custom kit gives a better JDM feel. :top:
Hahaha Supra_Fanatics... dun la like that.. its a matter of preference ma.. i have other daily drivers so i can go wild over this baby.. err my front is still JDM only customed.. but soon will be making a complete new front face.. need to accomodate the new fmic..thanks btw bro ;)
U just gave me a shop to consider for custom bodykit. Previously I went to one in Sunway. RM3K for bodykit but paint is costly, using glasurit lacquer.
Thought of sending to a fellow friend in zth instead for paint.
Really nicely done la. The design u actually draw it urself? Really good drawing.
Really when it comes to custom body then u r at the mercy of the painter most of the time, body shop are good at shaping up the panels but dont really have a good final touch to the finished surface, hence a good painter is essential.. my car was stripped down to metal.. sand blasted to bare metal and reworked up.. cost a bomb but worth every penny when its a collector piece..
Yup i designed the kit myself.. its not the best looking kit in the world but its more satisfying than paying ppl to do it..
Using Adobe illustrator? I assume u trace the shape of front, side and rear 1st before applying any bodykit design that u have in mind? Very nicely done.
I think u can print it on T-Shirt LOL!
ok. TD04-09 does share the actuator gate with exhaust. that's why u need to weld a plate to devide them into two row. then makesure the surface of the mouth then is machined flat so no gap when install the dumppipe flange.. a plate 5 mm or above shud be enuff for the devider plate. get a mild steel plate and weld it using oxy-gas weld since the housing may be cast iron. u may use MIG but makesure u not how to pre-heated the housing 1st..
---------- Post added at 10:48 AM ---------- 6 hour anti-bump limit - Previous post was at 10:47 AM ----------
the EWG position u can use elbow to mount it abit farther from radiator... n BTW nice custom turbo flange u done there..
Yup. Thats what i did back then.. illustrator gives u much freedom to shape lines and is always my preferrence for styling design.
---------- Post added at 11:11 AM ---------- 6 hour anti-bump limit - Previous post was at 11:09 AM ----------
Yeah be looking at getting the exhaust housing properly made up as its going to be a part which could be reused in the future. For EWG im going to wait till the turbo has been properly mounted before i proceed to make the downpipe
Bro, GTProshop aka monster garage if not wrong is in JOHOR?
what u can do to the actuator valve is install a bracket holder to hold the gate to always open. dont weld it permanently as it cant be use in future if u want to sell it. the devider plate is a no brainer as people can use back actuator n custom dumppipe if there's no EWG.
Gtproshop has closed down bro.. now the boss is into Cf business
---------- Post added at 12:10 PM ---------- 6 hour anti-bump limit - Previous post was at 12:08 PM ----------
Im planning to make it a fixed thing.. hehe.. no intentions to sell the turbo anyways.. probably buy a spare to keep rather. thanks for the pointer anyway..
u need to put some spacer between those 2 plate...atleast around 1"-2" for easier access to flange bolt/nut
front knuckles with oversized balljoints. And custom fitted hubs for rear..
Pomen gtr. Im reversing the turbo bolts so it mounts from the front side rather than the rear side.. making it easier to remove in the future.
ohh.. so u r using countersunk bolts for the turbo flange? better to drill the stock exhaust holes to fit the same size as the TD04 hole..
---------- Post added at 01:27 PM ---------- 6 hour anti-bump limit - Previous post was at 01:26 PM ----------
ur going to custom ur rear lower arm? is it a L5 disc equipped or stock?
Err no actually.. im going to weld the bracket dead to the original manifold.
Its going to run full waja hub assembly, disc and calipers.
oh ok.. u suggest the flange hole to be drill the same so the gas flow would be better.. see attached image.. that hole would be better u u drill to same size.. just my opinion..
Oh haha.. the difference is for welding.. im asking the welder to fill up the difference and i will grind it down to size. The grey part is actually the manifold end while the red piece is the add on adapter.
This is what im trying to achieve.. :)
You also using Solid Works....Hahaha...I have also but not daily use....still not really good at it though but nice software to draw technical stuff...and design
