[Urgent] Where to make Oil Cooler Lines?
is it the oil cooler hose ah?
use the conventional gas cooker hose
I actually need the clamps only, to clamp the fittings and hoses.
But since nobody we know that has it, have to take everything lo.
If use garden hose clamps cannot meh? or maybe able to find a specific clamp at hardware shop,
buying a complete set is a waste of $$$.
u pasang the cooler edi ah?
u pasang edi the cooler edi ah?
No la, need to clamp the fittings ma. Sort of like metal fittings.
Those anodized ones.
I think you mean "crimp fittings" where you joint the hose and the ends together.
https://www.google.com.my/search?q=...m%2Fproduct_detail.aspx%3Fid%3D251634;440;285
Yup, some air con shops does it....
---------- Post added at 10:46 PM ---------- 6 hour anti-bump limit - Previous post was at 10:44 PM ----------
At first I also think can just go spare part shops get the hose clamps....hahahhaha:biggrin:
Stupidcar,
I oso made power steering line, ATF cooler line from that workshop too...
Hihihi,
Anyone knows where to make oil cooler lines?
Or at least where to clamp those fittings?
Thanks.
Hi bro.
are you in klang valley? in shah alam there is one shop call Inland industrial Instrument. They are do lot of hosing work. Work next door to them last time. might it help.
Inland Industrial Instruments (M) Sdn. Bhd.
Address: No. 23, Jalan Juruanalisis U1/35, Seksyen U1, Hicom Glenmarie Industrial Park, Shah Alam, Selangor, 40000
Phone number: +60 (0)3 5569-5199
Hi bro.
Hey thanks.
Hihihi,
Thanks.
if clamp/hose type just use hose clamp and oil-rated hose
if the threaded type bring oil-cooler and screw banjo fitting to tracktor/jcb sparepart/machine shop and they will do custom hose for you....
The Earls (Blue-Red color) fitting sold at shop area sunway. You can search it from mudah.my.
But I use industrial clamp and fitting for my oil cooler hose. You can visit any hydraulic shop and ask them.
Gas Cooker hose can withstand oil?
can kua cos its quite thick, usually used to connect oil catch tank.
I wouldn't use gas hose. It can take the pressure but it's relatively stiff. Those clamps will not be able to clamp down to a tight seal that can survive the pressure. I've tried using before and ATF leaked out from the clamps. Worst case scenario for me the clamped section popped out right because too much pressure.
