- Joined
- Aug 14, 2006
- Messages
- 66
- Points
- 1,508
Wira Handbrake light OFF even i have pull up my handbrake...
Do you guys know what is the problem?
Thanks.
Thanks.
Dismantle center console. See if the switch is connected to the handbrake. If it is, replace the handbrake light bulb.
it's a light bulb for the handbrake warning light in dashboard?
not sure is there a fuse for this...
Oh you mean your dash handbrake light not working. Look under the driver side fuse box and find the in-cabin fuse. See if that is burnt. Anything else not working? Like ceiling light or anything?
I further confirm by pressing level sensor of brake fluid... still no lights come out...
It is highly suspect the handbrake warning light kong... but wonder why LED can easily kong ... =.=
Wira using LED? Or u changed it?
How old is your dash? Mine rosak after 8 years. Swapped everything out regardless of whether they spoilt or not.
Those aren't LEDs, kinda like mini bulbs. I replaced the bulbs only! Not the whole meter
