Wira Handbrake light OFF
Kyusuke_FD3S
Wira Handbrake light OFF even i have pull up my handbrake...
Do you guys know what is the problem?
Thanks.
Dismantle center console. See if the switch is connected to the handbrake. If it is, replace the handbrake light bulb.
it's a light bulb for the handbrake warning light in dashboard?
not sure is there a fuse for this...
Oh you mean your dash handbrake light not working. Look under the driver side fuse box and find the in-cabin fuse. See if that is burnt. Anything else not working? Like ceiling light or anything?
just checked driver side fuse box and under hood fuse box... looks like no fuse for this ...
after dismantle the console, the wire is still attached properly ... perhaps, the switch kong d ... :hmmmm:
not the bulb? More likely the bulb in the dash rosak than the switch kong ler
I further confirm by pressing level sensor of brake fluid... still no lights come out...
It is highly suspect the handbrake warning light kong... but wonder why LED can easily kong ... =.=
How old is your dash? Mine rosak after 8 years. Swapped everything out regardless of whether they spoilt or not.
Wira using LED? Or u changed it?
i guess these are LEDs rite?
---------- Post added at 02:58 PM ---------- 6 hour anti-bump limit - Previous post was at 02:56 PM ----------
the meter console is not cheap ...
what is the thing that rosak for ur case ?
Those aren't LEDs, kinda like mini bulbs. I replaced the bulbs only! Not the whole meter
i see... likely is the bulb blur then ...
aiks ... lazy to dismantle all the stuff ...
install back have to make sure the speed cable properly sit into the meter
