Hi i have cel 41 i do a mistake put a wideband 5volts on 1 volt ecu have fix?
ECU P28 M01 d16z6.
Hello E-tech and everybody in this great forum. I have here a P2E that when installed in the car the transmission shifts poorly. I used a borrwed P2E from another car and it shifts perfectly. Any ideas what could be? or maybe where I could start looking? I am good at soldering/desoldering/reballing bga's etc and have equipment... I just don't know where to start looking. Any help would be appreciated.
sir,
i have problem with my p08 ecu..
datalog show the tps sensor when full throttle only 6%, and when close throttle is -10%, it's make idle came rought, how i do to fix this case?
i try with my friend's ecu p28 my car idle stable, how must i check in the ecu board?
sorry for bad english
Masalah anda di kawasan ini kalau betkaitan
dengan TPS... semua capacitors wajib di tukar.
semua capacitors sudah di tukar, tapi tidak ada perubahan..
kira" apa lagi yang perlu ditukar?
Hai,bro, need your helps, my car idle problem , idle up and down very weird , and after check the code, we found code
---------- Post added at 10:31 PM ---------- 6 hour anti-bump limit - Previous post was at 10:25 PM ----------
I found code 14 (aic valve problem) But after I reset the Ecu, it didt show any code, but after I start the car it come out again code 14? FYI I have change all the 7caps. But problem still the same, idle up and down.pls help me,this problem already 4months.pls advise which Ic or Transister or resister have to change it??
Hi E-TECH ,
I have a question . if normally switch on the car the engine light will off after 2sec , it mean no error code its ?
at this moment , I connect the two pin plug n check the error code , the engine light just on and not blind at all .
So , its normal or problem ? Thanks .
Thanks for reply E-Tech .. Hope not ecu problem la .. Any hits if ecu problem ?? Can check ?
I don't trust sim either!
Car primes fuel pump, car starts and runs fine.
Yes goes over 4500rpm
I'll be letting go of my pride & joy for something new to work on
.. Yes the southern 300bhp 1zz MRS is for sale.. specs of the ride as below;-
