Is it ok when its below 0 bar the sound from the turbo like 'wu tu tu tu' how r34 sounds like. But when in 0.5 in sound 'kepishhh' . Cause i read from some forums that 'wuu tu tu' sound can dmg our turbo. Im new to turbo. Can someone tell me?
But 0 and below where got boost? That is why no 'kepishhh'
seems like the BOV spring adjusted too tight when close throttle there is not enough vaccum to keep open the BOV...but the turbo already pumped some pressure inside the piping hence tu tu tu tu compressor surge....
me everytime drive half spiritedly sure got that sound....only way to reduce it push the throttle more and make proper boost before releasing throttle/change the gear![]()
if the bov spring too soft. then you'll be annoyed when your bov "kepish" too frequent.![]()
