or maybe i could recommend a technician for the job.. familiar with campro engine,does the things according to manual book.
hi bro. i decide to upgrade my 1.3 to 1.6. any recommended workshop that can be trusted ?
Sorry to bring this tread back.i am assisting a friend whom is hell bent on doing this upgrade.
i understand to go from 1.3 to 1.6,only the stroker kit needs to be change.his mech quoted rm 2000-2300 for the job.kinda cheap right?
Need someone to shed some light in this matter.
currently his engine is all stock except for 4-2-1 extractor.gb is manual.For RM2000,what bolt on part can be installed?
I am looking at;
-camshaft
-pulley
-others?
He is not going for outright power and i wont encourage him so as he is still new and once oversteer the car which nearly hit by an oncoming car.
I am looking at;
-camshaft
-pulley
-others?
Uh.. ok I'm not going to respond to the oversteer part. But for the 1.3 to 1.6 upgrade, you need the injectors and ECU I should suspect. Probably can do without ECU for now and just monitor whether it runs lean or not.
Camshaft, pistons, conrods and injectors. Pulley for what? Same la.
if thats so, Saga and Persona group in Lowyat Forum has a few people did it.
Piston not same size? most have longer stroke only?
Thanks brother TR, means same as some older engines like Ford 1.3 and 1.6. Piston are the same, only the crank stroke is longer for larger displacement.
Thank you bro tr...very helpful.
Rm2300 for 1.3-1.6 conversion sounds too cheap right?
His other option is to ratain the 1.3 internal part and just upgrade the bolt on part like pulley,camshaft and so on.
i guess the ourcome is roughly the same eh?
