Just changed 4 engine/gb mountings for Rm230 mountings and RM250 labour. is it reasonable?
depends on wat brand, mine I bought MMC rm65 - rm70 per pc (without gbox mounting as mine was manual tranny), workmanship less than Rm100 as its quite easy to fit 3 mountings. not sure on how hard is it to fit the 4th mounting (gbox mounting).
Not the usual front, back, left and right?
the usual 3 mountings had been changed, but the 4th mouting (gbox) has not been changed since I had the car for 6 yrs. the mounting still in good condition
hi all,
im nubis here..want to ask what size piping fit for v6tt.. 2.5inch or 3 inch?
pls do help me abit confius choosing for this two...![]()
So it differs? Mine, front and rear always suffers damage if do a lot of pick up as engine rocks forward and backward. The left and right ones usually last as that is just to hold engine up....![]()
the best is using 2.5", before this I was using 2.5" from front till mid, then mid till muffler 3.5", exhaust will pop at high boost. (1.1bar).
---------- Post added at 09:00 AM ---------- 6 hour anti-bump limit - Previous post was at 08:58 AM ----------
mine is V- configuration engine maybe can lasts longer kua.
then mid till muffler 3.5", exhaust will pop at high boost. (1.1bar). does it pop like anti lag open firing
nope...pop like not enough fuel![]()
should try tat.... now i'm using 2.5" and g medallion muffler. very quiet exhaust almost like stock. but sometime feel bored on it so thinking of getting some noise from it.
Hey hey, if you want to dump that G Medallion, I'm more than willing to take it! If it fits NA V6.should try tat.... now i'm using 2.5" and g medallion muffler. very quiet exhaust almost like stock. but sometime feel bored on it so thinking of getting some noise from it.
[/COLOR
Juat curios,how to make it burble louder?
check engine signal continues...
