what's the best engine for my perdana...
RVR is abit lower HP but much more affordable. evo 3 much more higher HP but halfcut easily go 10k price. FTO's mivec is also good N/A engine. VR4 is also ok but too old hence alot of parts need to change. u choose..
RVR is what engine?
Evo 3 is 4G63T, unknown hp, range from 140-200.
Fto mivec, i think its the same with 6A12. :confused:
rvr is mitsu MPV, but similar engine to evo, just that RVR IC is on top. those placed infront is RS version.
evo 1,2,3 approx. 280hp.
RVR 240hp
RVR RS 260hp
vr4 220hp
vr4 rs 240-260hp.
if u have 6a12tt engine u get the fto mivec head the hp will be fantastic.
there is a mivec version for 6a12. eg: fto.
the head comes in a pair.
RVR 240hp
RVR RS 260hp
vr4 220hp
vr4 rs 240-260hp.
VR4 lower end have a 200bhp cyclone model.......mine....hahaha:biggrin:
Then Vr4 will tapau ur VR2? :confused:
As far as I know the 2 lower version of 200 and 220 have different ECU only, the 240 version RS ECU cannot be used by the other 2. When my ECU kaput I replace with 220 ECU, but I don't think it did anything much....:smokin:
its the same like any other N/A car. RVR n/a is similar to perdana sei engine just with DOCH.
If V6 Perdana can fit RVR 4 cylinder engine?, meaning engine mounting same?:smokin:
Same boss..engine mounting left right just fix the 6a12..front gearbox mounting SEI mounting and rear gearbox mounting any 4wd manual/auto from E54 model..
if perdana sei/gli year 95-99 - able to fit any 4G63/T engine, mounting is the same,
but if convert to 6a12/tt need to mod the rear mounting.
v6 version - 99-2013 6a12 convert to 6a12tt just plug & play, rear mounting need to refabricate if change to 4g63t engine.
Means as long as V6 to 4 in line or vice versa need to mod rear mounting....got it.....:driver:
