For Campro 1.6, 20W50 is 'recommended' in the manual book. Though, it seems to quieten the campro only, and it will decrease your engine performance. Too heavy.
the recommended service interval is 10,000km and use 20w/50 mineral oil. but many are worried about the oil couldnt last so long, but its factory recommended, they should have tested it. another option, go for semi syn 15w/40 and change every 5000-6000km.hello all. saga flx 1.3 executive driver here. family car. bought 2012. anyway. great stuff posted here. learned a lot.
so far i got 4 problems with it.
1. rear left door. the rubber strip did not fit properly causing a lot of force required to close the door. if not strong enough the rubber will absorb the shock and door not properly shut. fixed at service center. the rubber is in place but still require force to close the door. dont bother about it anymore.
change the weather strip ...its not expensive, cos when they produced the car, somehow somewhere someone fixed it not align from end to end. after so long, don think you wanna waste time to ask for warranty claim.
2. front right tyre always lose pressure. went to workshop to check and found a very small hole at the rim. since i plan to change the rim, it remains unsolved and got to pump up the tyre every week.
rim can repair, go to tyre shop, they can actually rectify the leak. if you are changing rim now, then ok, if u still need to drive, for safety purpose, don wait...and low pressure tyre will spoilt yr tyre too.
3. starting problem. sometimes after driving a distance and stop, my car wouldnt want to start. but after a +-2 minutes wait, try again, and it started. i suspect its the ecu while my cousin told me its the fuel line problem.
i think is yr fuel pump. campro has the tendency to have failed around mileage 80000km. get it replace.
4. when descending a slope, therell be sound produced at the rear end. i suspect its the rear brake trying to keep the car from going too fast.
since u go for tracking...try check yr rear drum brake pad.
anyway, i love it. being a boy easily influenced by ken block and the others, i actually do track driving with it. well. kinda. its slow and might be stupid but thats how i enjoy my saga. big plans for 2014. particularly in the handling department.
thanks for having me here.
ohya. i read a post stating fully synthetic not good for saga. really? because i changed to syntium 1000 in my last service. #becauseracecar haha. but seriously, really?
all the above are from my own experience & some 2cents....hope it can help.
i am not sure....but thats what stated in the service booklet.U mean the thicker the oil, the longer u can use?
I am using 1.6, with fully syn. just 5-6000km, its already damn dark.
hello all, which tyre did u guyz use with ori rim,
currently need to change it...
I changed to 15"
If you are a normal driver, the Synergy M3/M5 would suffice
If not, Continental CC5
I changed to 15"
do avoid synergy m3/m5 tyres, I bought mine brand new, within 6 months the tyre was swollen, summore my car only used during weekends.
how about the price between those 2 ....
my next service 60km ... is it major service![]()
thanks ericmaxman ... will survey area kajang/bangi which shops give the best
:rolleyes: super major service ..... maybe can start learn DIYing![]()
Hi guys, im new in malaysia and going to buy saga blm 2009 automatic. Need your advice if it is going to cost heavy in maintenance if car is in ok condition. Thanks in advance and sorry if this is not relevant
I find the persona can give better mileage
Not the way bro. stupidcar drives..........faster cabut......hahhahhahahhaha![]()
...to me or i buy it......need it to complete some DIY project....
